Old 11-03-2012, 11:15 AM   #1
Nordic
Nordic's Avatar
Where to get caster shims
Took the truck out of my street for the first time! Fun!!! Went and had the toe in set corectly and camber checked ok, I need to add 4 degree caster shims, who sells them? Steering seems to have play need to check box for adjustment next.
Nordic is offline   Reply With Quote
Old 11-03-2012, 12:08 PM   #2
mknittle
mknittle's Avatar
Re: Where to get caster shims
4 wheel drive shop. get the steel ones the alumnimim ones deteroate and cause electrolisis.
http://www.4wheelparts.com/Lift-Kits...=101&t_pt=5502
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-03-2012, 09:49 PM   #3
olskool68
How did you determine what degree of shim to get? Did the alignment shop tell you? I ask because I'm swapping out my original axle to a dropped axle and when I pulled the old one off, there were shims on both sides. One was cracked and the other, well, just rotted away from YEARS of elemental assault. I can't wait to get our project out! Thanks and congrats!
olskool68 is offline   Reply With Quote
Old 11-05-2012, 09:10 AM   #4
Nordic
Nordic's Avatar
With no shims i have 0 degee caster. Every thing I have read says that you need 4 to 6 degrees of caster when using power steering with the straight axle. I am going to try the 4 degree first because right now the "wander" is not outrageous. Found a set on ebay from Ca.
Old 11-17-2012, 12:55 PM   #5
zenchal26
zenchal26's Avatar
You can get them from napa I'm running 6 degree with a 3" drop axle.
zenchal26 is offline   Reply With Quote
