Old 11-04-2012, 03:19 PM   #1
75chev4x4
75chev4x4's Avatar
bushing replacement on stock springs
Hey guys I got a set of stock Chevy 3/4 ton front leaf springs and I ordered a set of energy suspension bushings to put in them. My question is I drilled out the rubber and got the metal part the bolt goes through and all the rubber out, do I remove the part that was on the outside diameter of the rubber bushing the real thin metal sleeve? Does this part come with the new bushings?
75chev4x4 is offline   Reply With Quote
Old 11-04-2012, 06:16 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: bushing replacement on stock springs
If your going to polyurethane just stop and return them. Unless your strictly drag racing they are useless
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-04-2012, 11:36 PM   #3
75chev4x4
75chev4x4's Avatar
Well the original rubber bushings are shot so I need new ones anyway and they are cheap enough. Also I heard more than a few members get them and liked them so that's why I ordered them.
Old 11-04-2012, 07:41 PM   #4
MTCK
MTCK's Avatar
I had to remove that sleeve when I put new bushings in a while back. Hang onto that inner bolt sleeve, you need to reuse that. Grease them up real good when installing, too.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-04-2012, 11:56 PM   #5
INSIDIOUS '86
They kill articulation and can cause binding. IMO there isn't much gain worth running these
Old 11-05-2012, 12:55 AM   #6
75chev4x4
75chev4x4's Avatar
Hey guys so I got those metal sleeves around the inside of the spring eye out using the sawzall. It worked very well except I gouged the spring eye metal toward the edge about 1/32" deep by 1/2" long into the spring eye with the saw blade. I cleaned up the metal and just filled in the cut with weld and ground back down with my die grinder. Just wanted to get your opinions if it is still safe to run or if I should just get another spring. I would rather be safe than sorry, stupid mistake on my part for not being more careful. Thanks guys
Its the very shiny spot in the bottom part of the eye near the front
Old 11-05-2012, 07:35 AM   #7
75chev4x4
75chev4x4's Avatar
Am I safe on this spring?
Old 11-05-2012, 12:58 AM   #8
75chev4x4
75chev4x4's Avatar
huh ok, the way everyone talked about them I thought they were the ones to have, I'll give them a try and if I don't like them I will swap back to the rubber. Thanks
Old 11-05-2012, 01:10 AM   #9
kris's66lwb
resident wrencher
There gunna squeak something mean my gf has them on her radius arms in her explorer an man the thing is never quite
kris's66lwb is offline   Reply With Quote
Old 11-05-2012, 01:24 AM   #10
INSIDIOUS '86
Have them on the rear shackles on my truck and the squeak like hell but I can't find or fund new ones for the lowering shackles
Old 11-05-2012, 01:33 AM   #11
75chev4x4
75chev4x4's Avatar
Thought you put zerks in and they were better?
Old 11-05-2012, 01:58 AM   #12
INSIDIOUS '86
On the front. I won't on the rear since those are supporting suspension parts
Old 11-05-2012, 11:03 AM   #13
kris's66lwb
resident wrencher
I think you should be
Old 11-05-2012, 11:09 AM   #14
75chev4x4
75chev4x4's Avatar
Cool, thank you!
Old 11-05-2012, 11:37 AM   #15
kris's66lwb
resident wrencher
It should take something very traumatic to break it.
Old 11-05-2012, 11:42 AM   #16
75chev4x4
75chev4x4's Avatar
Yea, I just wanted that saw blade groove filled in and smoothed out cause I knew the groove could cause a crack. I will prob just use the hack saw to get the rear ones out.
Old 11-06-2012, 03:35 AM   #17
MTCK
MTCK's Avatar
I used a hack saw to cut one notch, then pounded them out with a chisel and hammer.
I'm not sure about poly bushings limiting articulation and causing binding. If you want them quiet for the long haul, get a set of greasable bolts and sleeves front and rear and be done with it. They are fine to run on both ends.
www.offroaddesign.com
I'm sure others sell them as well, but I have their hardware on my truck and the quality is good. It also seems to flex just fine.
-Marcus
Project Plow Truck
