Turn Signal Switch
What is the difference between a 1963 turn signal switch and a 1964-66 switch? I have a 63 column in a 66 truck and need to replace the switch. I do not currently have reverse lights, but want the ability to add them later if I choose. Not sure if that logic is routed through the switch. Thanks.
Re: Turn Signal Switch
I believe the reverse lights were activated by a neutral safety switch that the shift rods engaged when placed in neutral.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
heres some illustration to help
Wow, that's a great diagram. Thank you.
Tags |
column, lights, switch, turn signal |
