11-10-2012, 10:01 AM | #1 |
4x4 guys, I need some info on transfer cases
Ok my 82. Use to be a diesel but now gas. Guessing the engine tranny both changed but unsure. It goes into 4x4 but grinds and when you try to take it out, it grinds. A guy that was going to buy the truck said it was just a ink age problem. What else. It goes in 4x4 but grinds putting it and taking it out. It's. TH400 tranny,, but not real sure what the transfer case is.
I posted it on the 4x4 page but got no responses, but after retreading it , I would not have what I was saying eather I'm actually trying to sell this truck and need to get this fixed Posted via Mobile Device
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
11-10-2012, 10:13 AM | #2 |
Re: 4x4 guys, I need some info on transfer cases
There might not be anything wrong with it. If you just lightly push on the shifter they will grind. You have to do it with one swift and deliberate motion.
Posted via Mobile Device |
11-10-2012, 10:19 AM | #3 |
4 low can grind are you sure you are going into 4 hi ? Also would be good to know if it is a 203, 205 etc might help the diagnosis. The first pic is a 205 in the truck and the second is a 203 out of the truck.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
11-10-2012, 12:10 PM | #4 |
On my turbo 400/ np203 it grinds too when I shift the transfer case even with trans in neutral. Don't think anything is wrong with it it has always done it. I andjusted the linkage it shifts better but still grinds. I just shut mine off shift to 4x4 and start back up and go.
11-10-2012, 01:20 PM | #5 |
resident wrencher
My 203 grinds going into lo lock wouldn't an 82 have a 208
11-10-2012, 09:55 PM | #6 |
I like the grinding, it lets ya know when it shifts.. lol. My 205 grinds every once and a while.
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
11-11-2012, 08:27 AM | #7 |
Kris, I don't know if its original, the was a diesel. One of the PO put a 350 in it. I will get under it later and see what it is. I didn't know the grinding was normal in these things
11-11-2012, 12:31 PM | #8 |
resident wrencher
11-11-2012, 11:58 PM | #9 |
You know I guess I should have added that its not just like a grind, like putting a standard shift in gear, it's like the gears are SPINNING. It's a fast grind
11-12-2012, 12:43 AM | #10 |
Your truck "should" have a NP208, easy to tell the case is aluminum. Grinding into 4lo is not out of the ordinary. Is it grinding when in park or driving?
11-12-2012, 07:30 AM | #11 |
In park, grinds in and out. I would like to mess with it today
11-12-2012, 07:50 AM | #12 |
The linkage could very well be messed up. My truck did the same thing, it was like the truck wouldn't shift completely out of 4-wheel drive. Look under the truck and adjust the linkage accordingly. Does yours have a body lift?
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
11-12-2012, 08:38 AM | #13 |
No , no body lift, I also need to remove the high hump and recut the hole in the floor. I don't even know why the high hump was put on it. The hole in the floor is not right and seems like the shifter hits it a bit
11-12-2012, 12:35 PM | #14 |
At one time, there was probably a 4speed in it. Hence the need for the high hump.
11-12-2012, 01:21 PM | #15 |
resident wrencher
My 79 is factory with the high hump. Did they go to a low hump with an auto and 4x4
11-12-2012, 08:17 PM | #16 | |
Be very careful when shifting a 203 into "loc", the planetary ring is a weak link in those things, especially the lighter duty "stamped steel" ones.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-12-2012, 11:42 PM | #17 | |
11-13-2012, 07:46 AM | #18 |
All 4x4's and all standard shifts (4x2 and 4x4) had a high hump. Regardless of whether your 4x4 was an automatic or standard, it came from the factory with a high hump. Otherwise your cab would never clear the transfer case without at least a 2" body lift.
11-13-2012, 12:49 AM | #19 |
resident wrencher
I know my truck is OG auto and 4x4 with a high hump I know we tried once to put a cab from a 2wd auto on a auto 4x4 frame and it wouldn't clear the xfer case
11-13-2012, 08:26 AM | #20 |
I look under mine and the regular size hump is still there. You can tell the high hump was added but the rest of the floor under the high hump was not removed
