Old 11-10-2012, 02:45 PM   #1
eric67m
eric67m's Avatar
Chevy front hub question / clarification.
I have some things laying around. Tell me if I have identified them correctly.
Picture 1. Dana 44 front disk/mile marker lockouts.
Picture 2. Corporate 10 bolt/selectro lockouts.
Picture 3.
Left. dana 44 rotor / corporate 14 bolt hub (rear disk swap)
Right. Corporate 10 bolt hub and rotor.
So both the front dana 44 and the corp 14 bolt have external fastners (corp has 8 larger, dana has 6 smaller fastners).
Correct me if I have this wrong
eric67m is offline   Reply With Quote
Old 11-11-2012, 01:04 AM   #2
argonaut
argonaut's Avatar
Re: Chevy front hub question / clarification.
Eric,
There are two type of Dana 44 hubs for Chevy's. From 73 to 76 they used and "external hub" design on the 3/4 ton trucks, which is what you have pictured in photo#1. From 77 and up the hubs are all "internal", exactly the same as your photo #2.
The answer your questions more precisely, the early Dana44 3/4 ton front axle you have pictures does indeed use external fasteners to fasten the axle shaft to the hub.
Hope this helps.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-19-2012, 06:44 PM   #3
danw210
69 K20
Pic 3 left hub is indeed from GM 14 bolt hub with a front rotor for a rear disc swap.
danw210 is offline   Reply With Quote
Old 11-19-2012, 09:25 PM   #4
eric67m
eric67m's Avatar
What is the interchangeability between 44 internal, 44 external and 10 bolt front s. I have heard that they are swappable from the knuckle out.
Old 11-19-2012, 11:18 PM   #5
argonaut
argonaut's Avatar
I can speak from experience about the two Dana 44s. Everything is the same except for the spindle, hub, hub inner bearing, inner bearing seal and obviously the hub locks. I believe, but have not verified 100%, that the outer bearing is the same.
I've never owned a 10 bolt but it is my understanding that they are virtually identical to, or at least interchangeable with, the internal hub Dana 44 from the knuckles out.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
