Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-11-2012, 07:16 PM   #1
Hart_Rod
Hart_Rod's Avatar
Supercharged 6.0...700HP
Ok, now that I have your attention, , I need help with new motor tranny combo for my 68.
What I want: 700HP, streetable, reliable and decent fuel economy, .
Building blocks: LQ4 motor with L92 heads, Doug Thorley 1 7/8th headers, TVS1900 Magnacharger, Aeromotive 1000 fuel pump and pressure regulator, 4L80E
Suggestion on cam and springs? Stall? Throttle body?
Hart_Rod is offline   Reply With Quote
Old 11-11-2012, 08:06 PM   #2
kpeztruck
kpeztruck's Avatar
Re: Supercharged 6.0...700HP
Rob, I believe Hot Rod magazine has done an article on a supercharged LS engine that made that on pump gas. If I am not mistaken, they had an inter cooled Kenne Bell supercharger, but the article should be a good starting point.
kpeztruck is offline   Reply With Quote
Old 11-12-2012, 08:50 AM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
Chevy High Performance did one with a centrifugal sc that made over 700, but I think it was a 6.2L. It was a couple months back.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-12-2012, 09:45 AM   #4
69trk
69trk's Avatar
Texas speed will hook you up on just about any questions and parts that you have or need!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-12-2012, 10:07 AM   #5
Hart_Rod
Hart_Rod's Avatar
Good info, thanks!
I've read a few articles on the centrifugals, and some of the big ones are making crazy HP (1500+ !!!!). I'm going with the Maggie because it's quieter and like the setup for the LS motors.
Thanks, do they have a website? (Edit: I found their site. Have you talked to them much?)
Old 11-12-2012, 12:58 PM   #6
68jewel
On the path to financial ruin!
68jewel's Avatar
Rob, I bought both of my LS's from Texas Speed. I highly recommend them. Great customer service.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 11-12-2012, 08:30 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
[QUOTE=Hart_Rod;5698287]
I've read a few articles on the centrifugals, and some of the big ones are making crazy HP (1500+ !!!!). I'm going with the Maggie because it's quieter and like the setup for the LS motors.QUOTE]
I know you have a screw-type, but I just figured you might look and see what cam/springs they used, or just gather some general info to get 700 supercharged hp.
Adam
Old 11-12-2012, 02:46 PM   #8
Super73
Super73's Avatar
Texas Speed is not a perfect shop.
Let me just say that my 418 short block they built for me had some problems. They were told from the beginning that it was a n20 motor, set the pistons in the hole with proper clearances and do not file the rings. Pistons were set with 3.5 thou and rings were filed 18/22.. They tried to tell me that is how they set up their motors seeing 300+ n20 hits. Funny, the piston mfg they used had different thoughts. Pistons needed to be 4.5 thou and rings 28/30. They eventually made it right by paying the bill at a local machine shop to fix the bores, I opened the ring gap up.
They also don't give you all the details regarding high spring pressures and stock rockers, what happens to valve tips and side loading on guides. They will sell you their .675 lift spring all day but not admit to the valve tip erosion nor the heavy guide wear. When asked about that, they might try to sell you a roller rocker which requires more spring to control the added weight over the valve. But they seem to negate the need for a better than 5/16 .080 pushrods. High spring pressure will cause push rod deflection. Oh the vicious valve control circle.
I could go on with other things, but I will stop there. I will just say, they are not forth coming with real technical info when you ask. For cookie cutter info, generic question sure, but not much more than that.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-12-2012, 08:04 PM   #9
68jewel
68jewel's Avatar
Sorry to hear that. I can only go on personal experience and the experience of a few of my buddies. But, there isn't a such thing as a perfect shop and at least they made it right by paying for it. Some shops wouldn't have even done that much and would've left you high and dry. So, they can't be that bad, even though they messed up your motor.
Old 11-13-2012, 04:50 PM   #10
sourkraut
sourkraut's Avatar
Will be watching
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 11-13-2012, 08:09 PM   #11
truckmanloco
Here ya go Rob
http://www.hotrod.com/techarticles/e...blown_alky_ls/
truckmanloco is offline   Reply With Quote
Old 11-30-2012, 01:40 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I had a decent experience with TSP, but that was just for a cam setup, not a built engine. From what I understand, PatG over @ls1tech still does some pretty sweet custom blower cams, and I think he has an off the shelf blower cam also. PRC dual springs haven't failed me, and I doubt you'd need more than that.
I assume your running DBC? Which bolt pattern is on the blower, the 4 bolt?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-03-2012, 11:41 PM   #13
raull
raull's Avatar
hello rob , here is a link to the shop who is helping me with my 5.3 TT short block and heads ,
http://www.mesabalancing.info/Produc...it=Drag+Racing
i will contact him tomorrow and ask him for some suggestions on what you want to do , he has build several TT's and supercharged ls motors
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 12-04-2012, 11:09 PM   #14
jmedero
jmedero's Avatar
I'm glad your keeping it simple. I would hate to see things get complicated in that new shop of yours...... Lol
Let me know if you need me to come over... I can sweep really well and do beer runs. Lol
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 12-05-2012, 03:33 AM   #15
68 TT
Still plays with trucks
68 TT's Avatar
You need to look at the LS9 cam specs from the Corvette ZR1 and see where Chevy is at to make 638hp with the supercharged 6.2 engine and the large L92 style intake ports. I don't remember how much boost they are using in stock form but if I remember right it was around 9psi.
A couple of turbo guys I know are making 600-650 to the rear wheels with stock cathedral port 5.3's running ~16 pounds of boost on pump gas. They are both running the same basic setup and are using the 2004 vintage Z06 Vette cam and the Patriot Gold valve spring package. Many runs down the drag strip with no issues.
This should give you some base line as to how much cam is needed to make the power you are looking for on pump gas. Base your boost level on the fuel you want to run and size the cam accordingly. Depending upon how much boost you want to run you may need a whole lot of cam.
With the right tune you can run quite a bit of boost on 93-octane pump gas. My old 87 GN ran 17 - 19 psi on the street with 93-octane fuel.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-08-2013, 12:18 PM   #16
Hart_Rod
Hart_Rod's Avatar
Ok, I finally picked up the powerplant I'm going to use: It's a 6.2/6L80E out of a 2013 Camaro SS with only 135 miles! Now, I've got to figure out if I want to delete the AFM/VVT because I plan on putting my Magnacharger TVS1900 blower on it......
Old 01-08-2013, 02:42 PM   #17
68Stepbed
68Stepbed's Avatar
<---is slightly jealous. Check with Mast motorsports on wether or not to keep the VVT or not with the huffer.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-08-2013, 02:58 PM   #18
Hart_Rod
Hart_Rod's Avatar
, will do!
