11-11-2012, 10:09 PM | #1 |
rochester carburetor single barrel monojet issues!!!!
I just rebuilt my monojet carb. Bolted it back up and fired up the truck and found the carb is leaking a fair amount of fuel on to the exhaust and intake manifold. and i cant figure what would cause the leak while running?
-Todd |
11-12-2012, 05:19 AM | #2 |
Re: rochester carburetor single barrel monojet issues!!!!
Bump
Posted via Mobile Device |
11-12-2012, 09:41 AM | #3 |
Without knowing where it's leaking from, I'd say the first thing to check is your float level. I don't recall off the top of my head what it should be on a monojet, but the little paper that came with the kit should have a listing for it. Also, if you have the old black nitrophyl float in there, they absorb fuel and get heavy, swap it out for a brass replacement.
That is of course assuming that you scraped off all the old gasket material, replaced with new gaskets and all the bolts are tight.
1971 Chevy K20 350/SM465/NP205 |
11-12-2012, 10:49 AM | #4 |
Active Member
On these mono's the gaskets won't cause the leak - but - as mentioned above the most common leaks are caused by fuel level overflow. The float is one reason and the needle valve seating is another. Inspect the needle valve and seat carefully.
There is one remote possibility that the fuel pump pressure can force fuel through the needle valve so if the above doesn't resolve the problem, you may need to check the fuel pressure.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-12-2012, 09:41 AM | #5 |
Junior Member
Sounds like the float level is not set right.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
11-12-2012, 10:39 AM | #6 |
Im new with carbs how do adjust the float?
11-12-2012, 10:53 AM | #7 | |
Active Member
11-14-2012, 07:58 AM | #8 |
Thank you all for the input. It was the float level that needed to be adjusted. She is running nice and strong! Thanks agIn.
11-14-2012, 10:13 AM | #9 |
Junior Member
Glad to hear that you got the problem solved.
03-21-2013, 01:08 PM | #10 |
So I just rebuilt my 1 barrel rochester b and did not set the float level. If gas has gotten on the gasket, will that need to be replaced after I properly set the float? This is if course a new gasket from the rebuild kit... it has dried out now.
03-21-2013, 09:27 PM | #11 |
The gasket should be fine as long as it isn't torn.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
03-21-2013, 10:14 PM | #12 |
Thanks Daner. I just got her started with no leaks. I need to adjust the idle intake as she dies when I dont have the throttle open just a little, its too cold to mess any more with it right now... but good news is that there are no leaks. Its the little victories, right?
