Old 11-13-2012, 10:44 AM   #1
Sixteen Tons
Sixteen Tons's Avatar
Monojet thoughts
Started rebuilding the stock Monojet on my 69 C10 (I6-250) last night, with a great kit from Mike's Carburetor Parts, so far so good, it was filthy inside and out so it's getting a good long soak. Anyway, as I was preparing to do all this, I did a bit of research and while over at the Stovebolt site I read that in their opinion a two carb progressive system is really optimal for the I6 engines. My understanding is that it compensates for some of the limitations of the original single barrel carbs shortcomings at low speeds. At this point I'm going to finish my rebuild and reinstall what I have, but what are everyones thought on a future upgrade to run a two carb progressive set up or even a two barrel carb, which I'm guessing falls somewhere between option 1 & option 2? I'm looking for a solid daily driver that runs well and as efficent as possible, not a 1/4 mile beast. Thanks and I look forward to the insights.
Sixteen Tons is offline   Reply With Quote
Old 11-13-2012, 11:14 AM   #2
martindc1
Re: Monojet thoughts
I think the monojet is just fine for a mostly stock daily driver. Just keep an extra fuel filter in the glove box. If it were me I'd save my time and money for something else. I always thought my K20 was pretty good on gas for what it was. I hauled firewood, dirt, gravel, mulch and pulled trailers and I thought it had enough power. The 67 was heavier and had 4.57 gears and it did better on gas than my 72 C10 which had a 350 and 3.73s.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 11-13-2012, 11:23 AM   #3
68gmsee
Active Member
68gmsee's Avatar
It all depends on what you want out of your truck. If you're looking for better mpg the extra carburetion probably won't do it but you will get slightly better performance. My 68 GMC has plenty of zip with the mono for highway driving and the little hauling I do.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
