Big back window conversion part 1
Most people dont wanna cut open their cab to see how it works but thanks to the over inflated egos and pices of these trucks, surgery is the only way i am gonna get a big back window cab. So here is the beginning stages of the tear down and what needs to be done to complete the conversion.
1. Brace your cab 2. grind away all the paint on inner rear cab pillars, outer cab skin inside door pillar, back lower portion of cab where inside cab floor bracing meets cab wall and there are spot welds connecting inner cab corners to outer cab corners which you will be able to see from underneath. 3. once paint is removed, I used a spot weld drill bit to remove outer cab shell. Also drill out spot welds holding inner and outer sections of rear window. 4. you should now be able to remove outer skin leaving inner wall. 5. My cab corners were toast due to tremendous amounts of fiberglass and bondo. Warning, drilling spot welds requires patience and a stable mind. lol. Last edited by thump16; 11-13-2012 at 09:12 PM. |
Re: Big back window conversion part 1
As you can see the damage to my cab corners. I wasnt able to drill out the final welds as my corners rusted out so the pieces just came apart. next step is to drill out welds holding inner cab wall.
1. take your time drilling inner roof welds taking caution not to drill through the inner roof welds and remember the inner pillar welds are more in number than you might think, some are in a stair step pattern. 2. I didnt drill all spot welds between inner and outer window cuz i was lazy. instead i drilled a few, enough to create gaps between the two surfaces and then i simply popped them with screwdriver since i have no intentions of using them again except for scrap metal patches in future. |
you can see how thin the roof metal is but take your time.
1. There is also a small tab on the corner of each side post holding the lower corners of the inner window onto the cab that must be removed also. |
Ladies and gentlemen, we now have room to start the conversion.
Now its time to look at the new inner and outer portions of the BBW panels.
![]() ![]() 1. I got these parts from a warehouse in AZ called Classicdiscounttruckparts.com 2. The outter skin $401.95, the inner wall plus two internal bracing posts $200.95. Shipping $165 truck freight to my door. 3. The stampings on these parts are of very good quality. 4. The inner wall corners come with the door latch striker mounting brackets already attached. These will need to be cut out as i am not cutting out the original striker plates. Leave the outer curved wings attached (do not cut) 5. I have attached a photo of what the bracing should look like from rear of cab with only inner wall installed. Take note of the tack welds holding the bracing on upper corners of inner back window panel and the plate portion covering the door latch striker plates. you may have to save picture and then enlarge to see the tack welds. 6. This is as far as i have gotten. I need to find out if i have to trim the front facing sheet metal that goes directly behind outter pillar or if its supposed to be there. |
the last picture from post above show the curved braces and the panel that covers rear of striker panel. I have not confirmed yet but looking at earlier threads from other members, it appears that you have to tack the lower inner rear window assembly to the rear outer skin to strengthen the whole structure. Members who have did this mod please chime in because it will be thanksgiving weekend before i finish this up. Thanks and i hope this helps you guys. I am not an expert by any means, i just hate having to pay people for stuff I can do. I havent event gotten to the front panel replacements to include steps. just gotta have that big window.
![]() Join Date: May 2011
Goodness, you've graduated to the "incredible people" status, those that perform incredible feats of engineering; ). Looking great !!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
Oh my.
![]() ![]() Join Date: Nov 2008
Ok someone's gotta say it, I'll be the A-hole. You've got AT LEAST $768.00 in that cab (not even mentioning the labor and welding supplies that will be involved) AND the inner steps you mention will be needed.
Wouldn't it have been cheaper (not to mention a helluva lot faster) to have searched for a big window cab that only needed the typical cab corners? |
#10 | |
Certified Car Nut
#11 | |
![]() Join Date: Jul 2007
Plus it has to be worth something to not have to contend with straightening out the normally beat up back panels of the cab off the donor truck. That will probably help ease the cost of that back panel quite a bit. |
Bingo! I envy you guys out west. Big window trucks on east coast mean big money.
Posted via Mobile Device |
Just watching
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
I am gonna grind off old mounting tabs this weekend and do a trial mock up of complete window with pics.
#15 |
That is one heck of a lot of work.
I'm sure lots on here will appreciate the documentation. Kim |
#16 |
We dont have those options of big cab hunting on east coast. Plus this truck has sentimental value & is rare auto truck. I have seen worse cabs rebuilt on this site. I am a 20 yr Air force mechanic, diesel,gas turbine engines, hydraulics etc. My cab build is not what i would call hard work on any given day. I made this thread for guys like me who dont want a bunch of trucks littering drive way. Just one that me and my baby daughter are going to cruise in. As far as welding supplies, my buddies are hot rod builders & we all barter & trade, help each other out. No cash involved & i forgot to mention, i have all the patch panels. Been planning this since earlier this yr. Have a good night.
#17 | |
Hollister Road Co.
Engines are allowed in the bedroom closet regardless of what the wife says if its an Aluminum BBC or a 427 FE, that's rule # 247. |
#18 |
2 in my garage now. No more room. Lol
#19 |
I am proud of me. This is my first old school build. Go team sledge!
![]() Posted via Mobile Device |
#20 |
![]() Join Date: Mar 2012
You realize that when you're done it will be like sneaking into the country club through the back door, right?
![]() Years ago when I lived in Massachusetts I picked up a deluxe cab Chevy truck with big window for $50. This was maybe in '84 or '85 and even then people commented on how hard it was to find one. I was a dumb kid back then and I traded that truck off for a '79 Caprice shortly after I got it. Nowadays it's rare to see any '55-'59 sitting around collecting rust in this area. Most of them have been dragged off for scrap metal prices. Finding one in rebuildable condition for reasonable money is likely to be only slightly harder than finding hen's teeth. I have mixed feelings about making the big window cab vs finding a "real" one but I can understand the desire and applaud the work that goes into it. |
#21 |
I apologize if i offended anyone with more than one truck in their driveway.
![]() The whole reason i did this was to show that if you want a big back window truck, its possible especially if you find a big window cab that is too far gone but you can save the rear window and back half. From what I have seen, alot of original BBW have major flaws in their build from factory allowing rust and imperfections to rot them away. I am taking steps to ensure my ride stays healthy and rust free. "Dan in pasedena" Being an Ahole is your God given right but don't smear it in my thread. This is my dream truck and I am a home builder. It's my money, my truck, my thread and my registration. I will continue posting this build as time permits and I hope there are more members that can benefit from my build thread. Sledge |
#22 |
Sledge, great progress! Can't wait to see it when it's all tacked up!! Keep at it.
#23 |
![]() Join Date: Jan 2009
Keep on posting up. This is good stuff. I can appreciate the determination and "damn right I can" attitude.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
#24 |
Thanks for documenting this conversion. I wanted a BBW truck but couldn't find one around here. I've been daydreaming about converting my truck using the full back panels like you are doing so I really appreciate this thread. I'll be reading and re-reading it.
#25 |
the only time consuming part is gonna be rewelding the panels together. Its pretty straight forward though. i had the chance to buy a complete big window cab and complete small window truck for a good price but I let it get away.
