Old 11-14-2012, 09:29 AM   #1
Daddy Brim
Daddy Brim's Avatar
Spedo Lube
The last couple of days since it has got cold my speedometer cable makes a strange sound, And the needle get all crazy. I think it needs to be cleaned and lubed. What do you think I should use.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 11-14-2012, 11:53 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spedo Lube
I have used a lightweight white lithium grease for the same problem, and it worked just fine. But the best thing is supposed to be graphite lube, especially in colder climates. Probably not a big concern in Clovis.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-14-2012, 12:26 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Spedo Lube
I take the cable off of the speedo head and spray PB Blaster into the cable housing, put it back on and run it for a while, then take it loose and spray it again. That usually takes care of it.
I don't recommend graphite on anything. The main problem with it is that people tend to use too much. It then absorbs moisture and turns into a gummy mess. I have disassembled a lot of lock cylinders that have had graphite used on them so this is from first hand experience....
LockDoc
Leon
Old 11-14-2012, 11:58 PM   #4
70cst
70cst's Avatar
Re: Spedo Lube
LockDoc
Good info. Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-14-2012, 12:19 PM   #5
domeier
domeier's Avatar
Re: Spedo Lube
I disconnected mine at the speedo and trans, put a drill motor on it and sprayed about half a can of gun oil/solvent down the housing with it spinning. Dry graphite makes sense for a new cable and housing, but for an old wore out one that's full of 40 years of gunk, this worked great.
domeier is offline   Reply With Quote
Old 11-14-2012, 10:00 PM   #6
Daddy Brim
Daddy Brim's Avatar
Re: Spedo Lube
I think I will disconnect both ends and try to spray some carb cleaner down. Then use some white grease. Does the cable come out of the housing ?
Old 11-14-2012, 10:17 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spedo Lube
Originally Posted by Daddy Brim View Post
Does the cable come out of the housing?
Yes, from the top (speedometer) end. I removed my cable, cleaned it, coated it with white grease, and re-inserted it.
In hindsight, I probably should have sprayed some sort of cleaner down through the housing.
- Mike -
RIP El Jay
Old 11-14-2012, 10:35 PM   #8
Daddy Brim
Daddy Brim's Avatar
Re: Spedo Lube
Good to know, I will pull it all apart this weekend and give it a good cleaning and lube it up. Thanks
Old 11-15-2012, 01:08 AM   #9
airdale94
airdale94's Avatar
Re: Spedo Lube
Gear oil also works good. Pull the cable out, pour some in your palm, then pull the cable through it.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 11-15-2012, 11:30 AM   #10
cdowns
cdowns's Avatar
Re: Spedo Lube
i was taught to clan real good// b very carefull if trying to wipe it down with the palm of your hand// then using graphite speedometer cable lube // was told and have read tech articles that the graphite actually polishes the inside of the cable housing for longlife and proper operation with less drag/// worst stuff to use is white lithium grease
Old 11-15-2012, 12:16 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spedo Lube
You may be right.... that's what I used more than 25 years ago and it's still working flawlessly. Mine is probably the exception though....
- Mike -
RIP El Jay
