11-15-2012, 12:06 PM | #1 |
what is this red wire?
where is it supposed to go
11-15-2012, 12:27 PM | #2 |
Re: what is this red wire?
This thread should help you out. But it looks like an alternator wire.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
11-15-2012, 12:39 PM | #3 |
Choke?
All your gauges working? Just acouple guess' Posted via Mobile Device
1955 Buick Special 1967 Chevy C10 "Hey dog...dog! Did ya see the size of that chicken?!" |
11-15-2012, 01:48 PM | #4 |
Active Member
Doesn't look like a choke connnector. I would follow it back to see where it goes and check to see if it has any voltage on it. Normally a pink wire is what is used for the HEI but not sure what that one was used for.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
11-15-2012, 02:11 PM | #5 |
yea i got no clue, i followed it back, it goes behind the distributor into a bundle of wires and then i lose sight of it. but all the gauges work fine and its apparently not hurting the truck running, its causing no problems i guess, but id like to know what it goes to. im sure someone on here knows where it goes to
11-15-2012, 02:23 PM | #6 |
i just looked at that wiring diagram and that wire isnt on there....im even more clueless now
11-15-2012, 05:24 PM | #7 | |
Also with this type of question a lot of basic information should be given like series 10 or 20, engine type and if original or a conversion. A/C changes things too. Trans. type and year make a difference as well. A '72 C10 auto A/C is going to have a very different harness than a '69 C30 stripper stick.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
11-15-2012, 02:26 PM | #8 |
The Older Generation
What year is your truck? Possibly for a TH400 kickdown switch. Would have been two wires to it though. Lockdoc
11-15-2012, 02:19 PM | #9 |
Here's where the red wire went on mine:
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
11-15-2012, 02:25 PM | #10 |
11-15-2012, 02:28 PM | #11 |
i thought it might have been the fast idle didnt think it was that big though
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
11-15-2012, 02:38 PM | #12 |
its a 72
11-15-2012, 03:05 PM | #13 |
Wide n'Low
I think it was originally for the idle / air control solenoid as pictured. Do you have a/c?
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
11-15-2012, 09:04 PM | #14 |
It is part of the TCS harness, plugs into the fuse block Ing. unfused, it suppose to be pluged into idle solenoid.
11-15-2012, 09:47 PM | #15 |
It is for
The a/c bump up when the a/c is engaged it would idle the truck up about 300rpm Posted via Mobile Device
1970 c-10 lwb named "heavy metal therapy" |
11-16-2012, 09:18 AM | #16 |
well i guess it seems i no longer have an a/c bump up then....a/c works still, id rather have the windows down anyway....thanks for all the help and answers guys
