11-16-2012, 04:43 PM | #1 |
Which block hugger headers aree you using?
Looks like I am going to have to use block hugger headers on my 5.3 AD with C4 front end. I have 3 sets of manifolds and C5 worked until I ran my brake lines now they are to close for my likeing. What is a good fitting brand to use?
11-16-2012, 07:42 PM | #2 |
Re: Which block hugger headers aree you using?
Why not just reroute the brake lines?
11-16-2012, 08:12 PM | #3 |
Fabricate till you "puke"
2nd that, but we all know that a pic is worth 1000 words crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-17-2012, 12:20 PM | #4 |
11-18-2012, 08:48 PM | #5 |
I used Hooker block huggers, They are a universal application header for no specific vehicle, with tight clearance set ups. Center dump, and they come out parallel and slightly pointed in at the top of the oil pan. Only about $240, I used them because I was concerned with the stock z-bar clutch linkage that I decided to stay with. They come very close to the back of the starter, but will work fine. I still am awaiting exhaust from there on out.
11-21-2012, 10:32 PM | #6 |
Hooker #2312
11-16-2012, 10:55 PM | #7 |
I used Sanderson CSLS1 shorties
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-22-2012, 12:19 PM | #8 |
I will match that ebay price of $240 shipped if interested.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
