Progress = 0%
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra Last edited by Slammed67; 06-03-2003 at 12:20 AM. |
My big dissapointment with my 74, it's bagged, is the drive height. Well the drive height at a decent psi. That looks like a good solution to both of your problems. Nice work!
74 swb 71 2wd Jimmy 82 2wd Blazer |
Progress = 0%
(added some pics)
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
i love summertime
lookin good, is your hood bolted on? or just sitting on the truck?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Almost Satisfied
![]() Join Date: Mar 2002
Looks great slammed. Any clearance issues with steering?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
#6 | ||
Progress = 0%
I really like it that low.....
Slammed, you prob already told me this but my retention is nill these days . . .... what size tire are you running up front?
What were you running for air psi before & what do you expect now? Thanks, Scot
Progress = 0%
SCOTI, the front tires are 255/45/18. The psi didn't really change too much. I have some cheap a$$ gauges, so I'm not sure what the exact pressure is. Before the modification, I was running less air pressure than I should have been because it rode too high. However, I think it took about 80-85psi to get the bags to ride height before. Now it's about 75-80psi to get the bags to ride height. Before, the bags were angled inwards slightly. Now they are pretty much sitting in there vertical, so it obvioulsy requires less psi. Once I get it back on the road (and get some better gauges), I'll figure out what pressure it rides best at. Are you running dial gauges or digital? I was considering going digital becasue it seems like it'd be easier to get the truck raised to an exact pressure reading.
I'm using dial but I'm actually considering one of the air control systems (AirRides or AccuAir). They are pricy, but I like the comfort of being able to return to alignment setpoints @ the touch of a button. Still debating though.
Those 18 inch rims look perfect for that truck. Nice job!
Getting cabin fever?!?!?!
very nice! why not remove the inner fenders? btw you need some more lugnuts!
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
