Old 11-17-2012, 10:25 AM   #1
savatreatabvr
savatreatabvr's Avatar
Tuning BBC for AZ EMISSIONS?
The dreaded trip to the emissions station! My experience with tuning vehicles to take through emissions hasn't been a good one, I've learned that adjusting and tweaking a motor to run it's very best isn't always always the best way to go! I've got the basics down, change the oil, plugs, cap & rotor and air filter but I need help when It comes to timing and carburetor adjustments to pass emissions! I'm assuming making it run hot and as lean as possible is the way to go, anyone know how to tune a stock mid 70's 454 with an Edelbrock 1407 and HEI distributer?
savatreatabvr is offline   Reply With Quote
Old 11-17-2012, 10:28 AM   #2
86c20
86c20's Avatar
Re: Tuning BBC for AZ EMISSIONS?
if you go to lean then the nox goes up and you fail at least where i am in mass. you should be able to lean it out some and i have heard about giving the timeing a few more degress will help. never done it so i do not know if that will work
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 11-17-2012, 11:45 AM   #3
bk2life
go talk to mike kelly at lopers on 9street and indian school.
he has a dyno and will tune your truck to pass emissions, then he will tune it after wards to make it run correctly for the rest of the year, you will gain power, and MPGs with the correct jets/timing/heat range spark plugs.
trust me, its worth it. i do it every year with all my toys. i cant tell you a price, becuase he gives me a "good deal" because ive been going to him for almost 20 years now.
tell him jamie from afghanistan told you to talk to him.
bk2life is offline   Reply With Quote
Old 11-17-2012, 07:17 PM   #4
savatreatabvr
Thanks Jamie, I live on 12th st. & highland so Lopers is right around the corner! Sounds like this is exactly what I need! You don't have to give me an exact number but are we talking $1 to $100 or $100 to $200?
Old 11-17-2012, 09:57 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
The timing needs to be run down to the point that mostengines barely run. About 5*btdc the carb will need to be re tuned for this change. You can try with the filter on or off. Make sure the engine is HOT a 195 thermostat and get the engine to full temp run low octane to ensure a complete burn and once it's all over change everything back
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-17-2012, 10:04 PM   #6
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I haven't changed my spark plugs/wires/cap/rotor since 1990. I just give the ol' 454 a long run on the freeway prior to the smog test to get it up to normal operating temperature. Passes with flying colors every two years. I don't over think it.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
