Old 11-17-2012, 07:07 PM   #1
White70C20
White70C20's Avatar
C20 tire sizes?
Ok, I was looking at the tires on my C20 the today. They're almost bald and very weather checked. The tires are 270R16s. I put my junkyard spare that has a 280R16 up next to it. I like the look of the taller tire on my truck (it is a 3/4 ton after all). It does have the Custom Camper pkg. What tires did those come with. My truck looks like a 1/2 ton with those smaller tires on it. Since I need new tires anyway, I thought I'd put the factory size on.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 11-17-2012, 08:05 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: C20 tire sizes?
Mine are 16.5"x 9.5". '71 Cust Camper.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 11-17-2012, 08:32 PM   #3
viking427
Re: C20 tire sizes?
The stock 16x6.5, 8 lug steel wheels wear LT235/75R16E or LT245/75R16E nicely with stock width & ride hieght. You can go a little taller (235/80, 225/85) for a pizza cutter look, but handling will suffer, especially with any kind of towing. You can also go a little wider such as 255/75 but should go to a 7" wide rim, like the Ford 16x7 8 lug steels.
viking427 is offline   Reply With Quote
Old 11-17-2012, 08:40 PM   #4
Mike C
Mike C's Avatar
Re: C20 tire sizes?
On my '70 Sierra Grande Custom Camper I ran 265 75 16 which were a great fit IMO. No rubbing and filled wheel well completely. About 32" 11.5 in inches.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-17-2012, 10:34 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C20 tire sizes?
IMO 265/75/16 are the perfect fit and look for C/20's
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 11-18-2012, 12:56 AM   #6
martindc1
Re: C20 tire sizes?
That looks sharp. Are those GM wheels? As noted above the 16x7 Ford steel wheels can be used and will accept a dog dish style hubcap like ones shown above. Last time I looked at tires it seems like the manufactures list a 7 inch wide wheel as the the minimum width for 265/75/16s, but we know that those tires are common on the GM 6.5" wheels.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 11-18-2012, 01:00 AM   #7
jocko
jocko's Avatar
Re: C20 tire sizes?
i agree with sicklajoie and mike!
Old 11-18-2012, 01:08 AM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C20 tire sizes?
I hate to admit it, but mine are indeed F*rd rims...
Old 11-18-2012, 11:19 AM   #9
martindc1
Re: C20 tire sizes?
No worries, I too bought the Ford rims with the intent of getting them sandblasted and powder coated white, but I never got around to getting that done, just ran 'em in their factory gray.
I like them though because I think they look like the narrower versions of the OE 16.5 rims but there are way more tire options and tires are much easier to find. They are common and available with a street price of $25-35 per wheel. Plus I think they widen the track width a bit and thus give the trucks a good looking stance.
Old 11-18-2012, 11:11 AM   #10
dads longhorn
dads longhorn's Avatar
Re: C20 tire sizes?
Sicklajoie, nice truck. I like that it looks pretty original. Thank you for that
dads longhorn is offline   Reply With Quote
Old 11-20-2012, 09:19 PM   #11
g mcmaine
TRKFRMR1
Re: C20 tire sizes?
I like the look also,what are the Ford models and years are they from?Maybe I can find a set in my local salvage yard.Thanks,Gerald.
g mcmaine is offline   Reply With Quote
Old 11-20-2012, 10:09 PM   #12
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: C20 tire sizes?
Any truck or van rim that has a 8 x 6.5 bolt pattern will work. Don't know the exact years though..
Old 11-20-2012, 10:28 PM   #13
viking427
Re: C20 tire sizes?
What 16x7/8x6.5 Fords left in bone yards today are mostly 90's E250 and E350 van. They're easy to spot from a distance because their fill valve is centered over a "window" where the GM and Dodge wheel's valve is centered over a "spoke". Ford and Dodge also had them in 16x6 that look identical, so make sure sellers know exactly what they have, I see the three mis-advertised all the time. The Dodge version looks like they used the same wheel blanks as GM, but added a small Chrysler Pentastar symbol on the face b/n the lugs and only came in 16x6 I believe, not sure if Dodge kept the smaller GM hub hole diameter or went with a larger hole like the Fords though. Any of them look good painted up with nice wheel covers and trim rings if you're really going out on the town
