Old 11-19-2012, 01:35 PM   #1
Bhelton
Bhelton's Avatar
6.0 swap
Ok here is another thread by me!
Just completed disk brake swap and have decided to to a engine swap to a 06' 6.0. I am looking for parts to make this easy and less work. So here is what's needed if someone could point me in the right inexpensive way I'd appreciate it greatly!!
Harness and ECM will go to Jim's performance unless there is someone else on the board that can do that part.
I want to run my 400 tranny since I just put $800 in to it....so is there anyone who builds torque converters to go from 1st gen tranny to 3rd gen engine?
Motor mounts....open to all suggestions
Fuel pump and regulator.... Open to all suggestions
A/C I won't to upgrade system and use the compressor off of the 06' model, I was thinking old air made a kit to do that?
Electric fan...again want to get the best bang for the buck
Power steering...I would like to tie the new pump into my current box
Bhelton is offline   Reply With Quote
Old 11-19-2012, 01:38 PM   #2
no moa
no moa's Avatar
Re: 6.0 swap
subscribed.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 11-19-2012, 04:16 PM   #3
Bhelton
Bhelton's Avatar
Re: 6.0 swap
So far I have found a tci flex plate to run 400 tranny....$269
Old 11-19-2012, 05:58 PM   #4
Bhelton
Bhelton's Avatar
Re: 6.0 swap
$575 for harness and ECM
$1490 for old air kit with new compressor and electric controls
Old 11-21-2012, 11:57 AM   #5
yossarian19
Re: 6.0 swap
I think there is like a $45 adapter ring to from GM performance products to run an older trans. Didn't need it for my swap but look into it. Also make sure your PCM is programmed for the right VSS speed signal for your transmission, the newer engines expect a higher resolution signal.
You need a higher pressure fuel pump, too. 60 ps for the 6.0
yossarian19 is offline   Reply With Quote
Old 01-18-2013, 12:16 PM   #6
bohmankid
bohmankid's Avatar
Re: 6.0 swap
Since he's using a th350, it actually doesn't matter what pulse the VSS is set to. Am I wrong? Cuz the trans is not electronic, he doesn't need to specify gears or tire size for his PCM either. Just disable the trans codes altogether.
bohmankid is offline   Reply With Quote
Old 01-18-2013, 12:36 PM   #7
ls1nova71
ls1nova71's Avatar
Re: 6.0 swap
Contrary to popular belief, you really do need a VSS for the engine to run right. It will run with out it, but not as well as it should, you can get stalling problems especially when coming to a stop quickly.
Anyway, here are the pics of the power brake fitting.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-18-2013, 12:59 PM   #8
Bhelton
Bhelton's Avatar
Re: 6.0 swap
You have that part number?
Old 01-18-2013, 04:48 PM   #9
ls1nova71
ls1nova71's Avatar
Re: 6.0 swap
Old 01-18-2013, 01:51 PM   #10
bohmankid
bohmankid's Avatar
Re: 6.0 swap
I know you need a VSS, I was saying it doesn't matter if it's, for example, 4000 pulse VSS or 8000 pulse VSS, since its a non electronic trans. It doesn't matter where the speed sensor is located or the number of pulses, just so PCM knows vehicle is in motion. Sorry i wasn't very clear on my statement above.
Old 11-21-2012, 06:49 PM   #11
Kainedogg
Kainedogg's Avatar
Re: 6.0 swap
'99 C5 and up regulator will handle your pressure needs. Just put a 6.0 in my 84 C10 using dirty dingo mounts and the stock TH350. Because my LQ4 is older (99-00) it has a longer crank shaft, so I only had to drill the flexplate to accommodate the TH350 converter. I am stumbling over the fuel issue now. Not sure what year truck you have but with my model you have the option of going to an '87 tank with intank pump. I already had an external Walboro 255lph pump, so I simply attached high pressure hose to the 3/8" supply side and drilled out the vent for a -6 bulkhead fitting for the return (not even close to the ideal way). Also using high pressure hose (350psi) for my lines. When I get the money, I will go with a newer tank for the turbo.
Kainedogg is offline   Reply With Quote
Old 11-29-2012, 10:48 AM   #12
Bhelton
Bhelton's Avatar
Re: 6.0 swap
Got harness off and sent to be shortened, new fuse and relay box installed as well as having CPU flashed. Waiting on parts for swap time to clean an dress engine up!
Old 11-29-2012, 03:46 PM   #13
LEEVON
Moderator
LEEVON's Avatar
Re: 6.0 swap
You don't need the expensive flexplate, there are 2 adapters, the GM one mentioned above which bolts onto the crank snout with the flexplate holes and the Hughes Performance one which just presses on to the snout. Either way, the goal is to extend the bearing surface to the torque converter somewhere close to .4 inchs. You can use the stock converter, make sure you have the "dished" flexplate that is common to 5.3's and you will have to waller the holes to the outside a bit to make it mate to the converter.
Less than $50 will get you there.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-29-2012, 04:21 PM   #14
Bhelton
Bhelton's Avatar
Re: 6.0 swap
If I can find the gm part number I will check it out and see if I can't save some coin
Old 12-05-2012, 10:03 PM   #15
Bhelton
Bhelton's Avatar
Re: 6.0 swap
New flexplate ordered, all electrical on its way back from Jim's performance, and a lot of goodies in the works...stay tuned!
Old 12-06-2012, 09:05 AM   #16
Clyde65
Clyde65's Avatar
Re: 6.0 swap
what are you putting the motor in?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-06-2012, 09:42 AM   #17
Bhelton
Bhelton's Avatar
Re: 6.0 swap
67 c10 swb step side, I'll post a pic of it here soon
Old 12-06-2012, 09:29 PM   #18
Bhelton
Bhelton's Avatar
Re: 6.0 swap
Pic of the truck...white front end will be leaving once tear down starts!
Old 12-07-2012, 05:16 AM   #19
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: 6.0 swap
If the 6.0 had a 4l80e behind it then you don't need anything to bolt up the older tranny. The flexplate on mine lined up perfectly to the th350. Once agin if your flexplate is flat then you are good.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-10-2012, 02:15 AM   #20
High ho silverado
High ho silverado's Avatar
Re: 6.0 swap
I bought a spacer and bolts for my 6.0 swap and when I went to put it on it already had one, duuuuhh! U mite check urs to see if it doesn't already have one, I'm not sure but I think 03 was the last year they had them but not sure
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 12-10-2012, 06:59 AM   #21
Bhelton
Bhelton's Avatar
Re: 6.0 swap
I will check, we ordered a flexplate to be safe.
Old 12-10-2012, 11:09 PM   #22
Bhelton
Bhelton's Avatar
Re: 6.0 swap
Harness showed up today, hope to see more this week
Old 12-11-2012, 10:57 PM   #23
Bhelton
Bhelton's Avatar
Re: 6.0 swap
Question for the experts....on the swap I'm doin being my 6.0 is drive by wire what do I do for kick down on my 400 tranny?
Old 01-01-2013, 04:04 PM   #24
ls1nova71
ls1nova71's Avatar
Re: 6.0 swap
Kick downs are hard to mount to DBW applications, however the 400 turbo is one of the easiest since it doesn't use a cable to the trans. 400's just use a switch to supply 12v when the accelerator is pushed to a set point. That said, you should be able to fabricate a bracket to mount a switch directly to the gas pedal, similar to the way they were on '71-'72's.
Old 01-01-2013, 05:06 PM   #25
Bhelton
Bhelton's Avatar
Re: 6.0 swap
I was thinking i seen a Lokar made kick down for the 400, i will have to look into what your saying first....Thanks!
