Old 11-21-2012, 10:45 AM   #1
mrhino
Holley Intake Manifold
Reconditioned Holley Aluminium Intake manifold. The Holley 300-38 Manifold is basically a low profile version of the great Lt1/Z28 high performance manifold of the late 60's &70's. some would argue, its one of the best SBC manifolds ever made. It should provide excellent low and mid-range power output from idle to 5500. This intake will except several different carb types and sizes, from Quardrajet, Edelbrock, and of coarse Holley.
The manifold has been bead blasted. Cleaned top to bottom, Inside and out. There is some slight pitting around the coolant passages, but all gasket mating surfaces are flat & true. All bolt and pipe fitting threads are in excellent condition, except the 1/2 heater hose fitting on the front, it should remain Permanently sealed. If your application calls for a heater hose in the intake You should probably pass on this manifold. The Intake is coated with a High performance tough durable finish with superior heat & chemical resistance for a cool modern look that should last a long time. Please feel free to ask any questions
Im Asking $85
mrhino is offline   Reply With Quote
