Old 11-22-2012, 12:58 PM   #1
84 400
Sb 400 club
84 400's Avatar
Front axle questions gears and six to eoght lug swap
Alright working on a 77 k10. Gonna be going 3/4 ton. I have 3 front 10 bolts. 2 0f the axles are 3:08's and 6 lug. The 8 lug axle is 3:73 but real rusty and has a leaking pinon seal.
are the caliper brackets bigger on the 3 / 4 ton?
Since the pinion seal is leaking am I going to have to set up my gears again? If so I will just swap them in the better housing.
Is gear setup really that hard on a ten bolt. It is something I want to learn and for the 200 plus it would cost to have it done I can pick up a decent mix.
Thanks for any input.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-22-2012, 01:43 PM   #2
b454rat
Re: Front axle questions gears and six to eoght lug swap
No need to have the gears reset for changing an oil seal. Just need to retorque it, usually less than if a new crush sleeve is used. The caliper brackets are a wee bit bigger that 1/2, but everything is interchangeable. I took a 1/2 front with killer 2.73s and swapped to 8 lug with the external hubs from a mid 70s truck...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-22-2012, 02:03 PM   #3
84 400
Sb 400 club
84 400's Avatar
So I need to source caliper brackets for an 8 lug?? The ones I have are rotted! So if I can change the pinion seal with out resetting the gears I guess o could keep the housing.
Also how is the vent tube installed?? Mine is rotted off!
1985 C10 LWB Sold
Old 11-27-2012, 06:48 PM   #4
martindc1
You won't have to remove the pinion gear, remove the pinion nut, pull off the yoke, replace the seal, replace the yoke, and tighten the nut down to the proper specification. You'll have to consult a shop manual or ask somebody on here what that specification is because if you don't get it tight enough you won't have enough bearing preload and if you tighten it too much then you will over-crush the crush sleeve and have to tear it apart to replace it.
Also you may want to check shop manual as to whether you need to change the pinion nut or use some locking compound. All of the gears I've setup used a pinion nut that was one-time use, but for full disclosure those were Ford 8.8" axles.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
