11-22-2012, 04:37 PM | #1 |
Rear gear ratio
Pulled my rear cover off and counted the teeth on ring and pinion
16 on the pinion and 41 on the ring gear, which means its got 2:56 gear ratio. Originally it had a 305 with a th350 trans. And I swapped in a 700r4 but I need to figure out which speedo gears to get. Seems odd that it would have a 2:56 ratio. Anybody else have a th350 and know what their rear gear ration is?
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
11-22-2012, 05:00 PM | #2 |
Re: Rear gear ratio
i dont recall trucks having 2.56? i thought 2.73 was the highest the trcks went. i have 2.73's useless on anything but the freeway
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
11-22-2012, 05:13 PM | #3 |
Re: Rear gear ratio
Yea 2:56 seems kinda odd to me
Got all the numbers off the ring gear: GM 1235401 16 41 11 83 Last batch "11 83" I think means built 11/83 which would be right in a 84 truck.
11-22-2012, 07:55 PM | #4 |
Re: Rear gear ratio
Yes, i have 2.56 with a TH-350C.
Stiff as hell. This kind of setup of good for if you use the truck for light hauling---lumber, appliances, weekend projects etc. It is not so good for other things such as towing. P.S. my GVWR is only 4900 and i guess yours is too. |
11-23-2012, 07:10 PM | #5 |
C/10 junkie
Re: Rear gear ratio
Are there two dots between the 41 and the 11. On my rear end there was which meant the ratio was 3.73, 41 divided by 11.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-22-2012, 10:57 PM | #6 |
Re: Rear gear ratio
^^^ Good to hear, so I guess I am identifying it correctly then.
I am fine with the ratio, I am dropping a 6.2 diesel in it and see what I can get for mileage with it. Not gonna be in a big hurry to get anywhere and more of a show truck than a work truck.
11-23-2012, 05:19 PM | #7 |
Re: Rear gear ratio
I was just now taking apart y rear end to clean up and paint and decided to check what ratio I have. It's 16 41 2 81. So I have a 2.56 as well.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
11-23-2012, 06:46 PM | #8 |
Re: Rear gear ratio
2.56 is actually a very common gear found in the 8.5's in both cars and trucks.
11-23-2012, 08:04 PM | #9 |
Re: Rear gear ratio
Is a 2.56 rear end useless? I've never heard of people wanting that high of a ratio...
11-23-2012, 08:17 PM | #10 |
Re: Rear gear ratio
11-23-2012, 08:20 PM | #11 |
Re: Rear gear ratio
Is the 2.56 at least good for gas mileage? I don't plan to do any towing or anything? Will keeping it affect my acceleration or anything?
11-23-2012, 08:56 PM | #12 | ||
Re: Rear gear ratio
As far mileage, probably good with a th-350 or other 3 sp trans. i think i tach around 1800 at 55 mph. P.S. It affects acceleration big time. Switching to say 4.56 will make a world of difference. |
11-23-2012, 09:13 PM | #13 | |
Re: Rear gear ratio
With 28" to 30" diameter tires & 3 spd auto......A 3:08 gear will return the best mileage in my opinion. 3:42's will give better acceleration with a small increase in fuel consumpsion at highway speeds. |
11-23-2012, 10:39 PM | #14 |
Re: Rear gear ratio
I am swapping in a 6.2, so these gears with an ole slug 6.2 and a 700r4 it will take a week to get up to speed but I will be able to pass a few gas pumps though
11-24-2012, 09:50 AM | #15 |
Re: Rear gear ratio
My truck had the 2:56 rear.. When I went with the 700 tranny, it was practically asleep on the highway with a 30" tire...found a nice posi carrier and 3:73 gears at the boneyard really woke up my TPI..
Posted via Mobile Device |
