11-22-2012, 10:07 PM | #1 |
Tunnel mods for 6L80E or 6L90E?
I am in search of an engine and tranny and I really like the idea of a 6.0/6L90E combo. I could not find much info on fitment. Is there anyone who has installed this combo in our trucks? What tunnel mods are required if any?
11-24-2012, 06:45 PM | #2 |
Re: Tunnel mods for 6L80E or 6L90E?
Anyone?
Posted via Mobile Device |
11-24-2012, 09:16 PM | #3 |
bbadfred
Subscrbed! Just bought a 6L90E today I will get under m7 67 tomorrow and let you know if noone else answers!
11-26-2012, 12:50 PM | #4 |
bbadfred did you get a chance to look under yours?
11-26-2012, 02:36 PM | #5 |
I have a 6.2 with a 6L80E in my Suburban. I ground the casting seem off the top of the case, and massaged the floor (low hump). It need to go up a little to give me the proper drive line angle, but its almost there. I didn`t want to cut the floor but i might install a high hump so i can play with the angle more.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
11-26-2012, 05:53 PM | #6 |
bbadfred
I have an LQ9/4L60E engine trans. I must have the tall trans hump because I have plenty of room for the longer and larger diameter trans case and the 1 1/2 inch longer length. I have CCP motor mounts and trans crossmenber.
11-26-2012, 09:54 PM | #7 |
There`s a difference in the height of a 4L60E vs 6L80/90E. the six speed doesn`t slope down as much.
11-26-2012, 09:56 PM | #8 |
11-27-2012, 03:33 PM | #9 |
That thread sort of helps but doesn't clearly answer whether or not if it will fit in our trucks. I hate to buy a trans and find out it doesn't fit.
11-27-2012, 07:43 PM | #10 |
It doesn`t fit with out mod`in the low hump floor.
11-27-2012, 08:35 PM | #11 |
kinda get an idea,
http://67-72chevytrucks.com/vboard/s...=269754&page=8
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
11-28-2012, 02:24 AM | #12 |
That's what I was looking for. Thanks!!
12-14-2012, 12:01 PM | #13 |
If you have a factory high hump, will you have to mod anything?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-15-2012, 07:49 AM | #14 |
There should be plenty of room with the high hump floor.
12-15-2012, 09:34 AM | #15 |
Who's motor and transmission mounts are you using?
12-17-2012, 08:51 PM | #16 |
I just used a plate style adapter, not sure of the brand, some left overs from a job. Reused the factory motor mounts. I had to lower the top of the motor mount bracket to clear the used set of headers i installed, but the motor height stayed the same.
I swapped the trans crossmember around 180* and made spacers so the mount would sit on the cross member at the right height.
12-17-2012, 08:53 PM | #17 |
12-18-2012, 12:46 AM | #18 |
As mine originally came with a 4 speed would this be a high hump or low hump. it now has a t400 but they have built a custom console over it so i cant tell .CHEERS
02-05-2014, 12:40 PM | #19 |
Still don't know what to make of all this. I read this thread which pretty much says tunnel mods will be required, but spoke with Mark at Street and Performance who has done this swap and says he didn't recall any clearance issues on the 67-72 platform. What trucks came with the high hump tunnel? How do I know if mine has it?
02-05-2014, 01:51 PM | #20 | |
02-05-2014, 02:22 PM | #21 |
Thanks Rob. Any idea what transmission tunnel you have?
02-05-2014, 02:42 PM | #22 |
67-72 Big block, 4x4 or 4 spd manual
02-05-2014, 04:20 PM | #23 |
I have the 6.0/6L80 combo in mine. It originally came with a low hump that had to be cut for a high hump cover. New holes were drilled for the high hump cover and it fit. No other cab mods were done.
Bird |
02-05-2014, 10:36 PM | #24 | |
Did you use motor mount plates that keep the engine in the stock location? |
02-06-2014, 12:26 PM | #25 |
It is close to stock location. I kept the mounts that came with the motor and fitted them to frame.
Bird |
