Old 11-22-2012, 10:49 PM   #1
bloodybigblock
bloodybigblock's Avatar
How well can it ride and steer? Cpp
On my 67, I'm considering Cpp products. I was gonna do a whole front end rebuild kit,full disc brake kit, every body mount and bushings replaced front and rear,and 5/7 drop using front and rear sway bars and upgraded trac bar. Can anyone give me a comparison of how well it will ride and steer vs newer trucks? If I pay about 3500$ for parts,I'd expect it to ride like a caddy. Thanks
bloodybigblock is offline   Reply With Quote
Old 11-22-2012, 11:33 PM   #2
Square_78
Square_78's Avatar
Re: How well can it ride and steer? Cpp
Id personally be looking into Porterbuilt stuff for that kind of money. Seems like a lot more money than you really "need" to spend tho.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-23-2012, 12:13 AM   #3
Justin36
Justin36's Avatar
I used CPP on my truck, and it really rides great! Also new A-arm bushings, upper lower ball joints, sway and track bar! Really pleased with it!
Justin
Justin36 is offline   Reply With Quote
Old 11-26-2012, 09:59 PM   #4
crazy longhorn
Fabricate till you "puke"
2nd that! My old truck has been out past 140....its a spooky ride after about 130? Backyard Buck style(cut coils /front, with shock relocators), flipped rear, ...less about 4 leafs on the stack/ slapper bars. The complete mess is budget , to the Hillbilly Bone.....she brings this crazy old man back, evry time out crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-26-2012, 10:04 PM   #5
Bhelton
Bhelton's Avatar
I just completed a 67 doing exactly what your speeking of and had less than $2200 in all of it. i shopped at 3 different places but saved a ton of money and even installed new brake lines
Bhelton is offline   Reply With Quote
Old 11-23-2012, 01:43 AM   #6
bloodybigblock
That kind of money? The majority of the money is for a complete $1600 brake kit. My truck has drums front and rear so its the best route for me. The total suspension may be around $800, Thats nowhere near the cost of porterbuilts products.I dont need air ride because of the cost and im more of a hot rod guy. I really like the autocross trucks by no limit. I just need my truck to ride like a new vehicle because when im finished, itll be my daily. Thanks guys
Old 11-24-2012, 01:32 AM   #7
jc70chevy
jc70chevy's Avatar
I did a 5/7 drop from cpp with front and rear sway bars and cpps shocks and its ride smooth and handles well i love it and never would second guess it
jc70chevy is offline   Reply With Quote
Old 11-24-2012, 02:19 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: How well can it ride and steer? Cpp
When you get done with the new components it will ride like a new truck!
It may not be the right year truck though!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-26-2012, 01:10 AM   #9
1970ChevyChamp
1970ChevyChamp's Avatar
I am also planning on using CPP to replace a ton of parts on my 67, the more opinions on there brake/drop/suspension parts the better,Thanks!
1970ChevyChamp is offline   Reply With Quote
Old 11-26-2012, 06:31 AM   #10
bk2life
in my perosnall experiences in any cadi I have been in, they all ride like a freakin schooner out on the ocean. I would be very mad if anything I drove felt like a soft floaty uncontrollable land yacht.
What type of ride are you really looking for? Corvette? Carve some corners? Not too stiff, not soft and sloppy like a cadi? A rebuild with new bushings, new coils, new rear leafs w/new bushings will make your truck ride like it did from the factory. Add some adjustable shocks and get it more tuned to the way you might like it.
Personally I like to be able to swerve around an object at 45 mph and not fishtail, rear end come out or other wards slide off the road and crash. That’s not a cadi or a corvette ride, that’s “safe”.
bk2life is offline   Reply With Quote
Old 11-26-2012, 09:36 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
You can really do a lot with a good agressive alignment, good shocks, and drop spindles.
Even if you spend a ton of money on a racecar chassis if you don't know how to set it up its not going to perform.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 11-27-2012, 11:19 AM   #12
bloodybigblock
Name those places please lol
Old 11-27-2012, 12:56 PM   #13
ItsRandy
ItsRandy's Avatar
It's all about compromise. Real good ride will make it mushy around corners. Real good around corners will make it ride rough. You can however make it ride pretty good and corner better than the truck that it is. My truck rides and corners better than my buddy's Chevelle but that's not a Caddy.
ItsRandy is offline   Reply With Quote
Old 11-27-2012, 09:16 PM   #14
Bhelton
Bhelton's Avatar
advance auto, oreilly auto, master power brakes, and daves truck parts...there was 4 places total not 3
Old 11-27-2012, 01:09 PM   #15
dmw319
In my opinion, if you want it to ride like a caddy, buy a caddy.
Its a truck! You can always improve general components that are older and probably need replacing anyways to improve it .. but its a truck! let it ride like one
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 11-27-2012, 01:15 PM   #16
chet
look at no limits rack and pinion. probably for the price of all the steering components you will be close to the same price. R&p is sooo much nicer
chet is offline   Reply With Quote
