Old 11-23-2012, 06:23 PM   #1
thekid54
Porterbuilt steering rack notches
Any pics of how much clearance there should be between the boots on the rack and the notches? I followed the notch install instructions, but it seems like notches are too far back towards the crossmember.
thekid54 is offline   Reply With Quote
Old 11-24-2012, 03:23 AM   #2
62 Bowtie
62 Bowtie's Avatar
Re: Porterbuilt steering rack notches
Same here not much help but thats how mine turned out
62 Bowtie is offline   Reply With Quote
Old 11-26-2012, 11:11 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
Post up some pics please.
The rack notch center line is located 4.25" forward of the front most mounting hole on the dropmember's main crossmember assembly (where it bolts to the bottom of the frame). The instructions have some good pics for reference as well. Let's see what ya got so we can help you get it figured out.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-26-2012, 02:38 PM   #4
thekid54
Nate, I followed the instructions per step 3 on your instruction thread. The pictures you provide appear to be on a different frame than mine. I have a 63-66 frame, but the frame shown in your pics looks like it might be later(?). Regardless, I used the measurements provided to make my cuts. The rubber boots on the steering rack are different sizes from left to right. The right (passenger side) boot rubbed the notch when I did an initial test fit and the left boot barely cleared. I re-checked my measurements and I was within 1/8" of your recommended measurements, but the interference between the boot and the notch was more on the order of 1/2". Even if the rack boot was perfectly centered within the notch it would still be a very tight fit. I came up with my own fix, but it cost me some time making it work. I'm not complaining in any way, your products are awesome. I just wanted to see if I messed something up and if so, others can be aware.
This photo shows how close the rack boot is without the notch in place. With the notch in place it would obviously interfere with the steering rack boot.
What I ended up doing was cutting the frame hole bigger, front to back, and enlarging the notch pieces. They're stretched approximately 3/4", front to back. Now the larger boot clears with ample room. Not sure what the issue was. Like I stated before, my measurement may have been off by 1/8" due to slop in my measuring tape, but shouldn't have thrown things this far off.
Here's a photo of the modified notch with the larger boot to show the clearance I gained.
Old 11-26-2012, 03:04 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
What measurement are you showing for dimension "X"?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-02-2012, 12:28 AM   #6
thekid54
Nate, for dimension "X" I'm getting about 4.5". It looks more like 4-7/16" in the pic, but I think it's the camera angle.
Old 12-03-2012, 11:33 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
Thanks for the pics and feedback. We are going to make that notch a little bit wider to help give some extra wiggle room.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-03-2012, 06:18 PM   #8
project 67 sub
project 67 sub's Avatar
So will mine have the wider steering rack notches then ?
project 67 sub is offline   Reply With Quote
Old 12-03-2012, 07:25 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
I guess that depends on when you order(ed) it.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-26-2012, 03:15 PM   #10
thekid54
Nate, I'm assuming you want that measurement with the dropmember/rack in place. I won't be able to get that measurement for a couple days since the frame is at my friend's house. The distance between the center-line of the front crossmember hole on the frame and the center-line of the frame cut-out was 4-1/4", +/-1/8". Thanks for taking the time to look into this, I really appreciate your superior customer service!
Old 11-26-2012, 03:30 PM   #11
PBFAB.COM
PBFAB.COM's Avatar
No worries.
I know it's a pretty tight fit to begin with... also, it appears that you made your notch cuts perpindicular to the frame rail itself (see pic below). This will compound the tight fit due to the fact that the rails pinch in at the front and the notch is no longer parallel with the rack. Add in the descripency of 1/8" or so and it will make it even tighter. Either way, I will be changing up the notch, making it a bit wider to add a little more "fudge factor" into it. Thanks for your feedback, we appreciate it. We are always open to feedback.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-26-2012, 05:11 PM   #12
thekid54
Nate, you are correct on the angularity of the cut, but when the notches were test fit with the rack they were parallel to the dropmember and the rack. (see photos 2 & 3 below). Even with cuts being slightly perpendicular on the bottom of the frame rail, that shouldn't affect the interference shown in the red circle below.
Photo 2: Notch parallel with dropmember and rack (this is after modifying my notch)
Photo 3: Notch parallel with dropmember and rack (this is after modifying my notch)
Old 03-01-2013, 08:03 AM   #13
64Downunder
64Downunder's Avatar
We just welded in out steering notch's today and have the same problem !!!!
As per instructions welded in the notch 4.25" from centre line of front bolt to centreline of notch.
Bolted the drop member with rack in and it's to close to the notch.
Pulled back out and double checked the distance and its correct.
So is this a common problem?
64Downunder is offline   Reply With Quote
Old 03-01-2013, 11:32 AM   #14
PBFAB.COM
PBFAB.COM's Avatar
Gary we received your message and will be getting back to you this morning. Or maybe it's afternoon down under?
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 03-01-2013, 11:15 AM   #15
ihssalky
I just did mine a week ago. They fit fine per the instructions. We did it on two trucks.
ihssalky is offline   Reply With Quote
