Old 11-24-2012, 05:59 PM   #1
tard01
Picture Request - brake booster -> pedal
adding a brake booster. The push rod / plunger that goes through the firewall to the pedal itself is different than the one that comes with my master cylinder.
my rod is 6-8" with a circle at the end that has a bolt go through it and the brake pedal.
seems all the brake boosters have a stubby 3-4" rod without a hole for a bolt. I'm sure there's a bracket or adapter i'm not aware of. curious if anyone with a brake booster could show me a picture of how it connects to their pedal.
Or is it a different pedal?
I found this thread from a few years ago, but not sure what that adapter is or where to snag one.
http://67-72chevytrucks.com/vboard/s...d.php?t=200437
tard01 is offline   Reply With Quote
Old 11-24-2012, 06:56 PM   #2
GM-power
GM-power's Avatar
Re: Picture Request - brake booster -> pedal
1st pic is where the rod connects to an adapter, which is mounted around the middle og the pedal shaft. the left side of the bracket hit a bumper to keep tge pedal up. 2nd pic is the upper mount on the pedal shaft. The rod coming off the brake pedal shaft is bolted to a support by the bolt in tge 3rd pic.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-24-2012, 10:02 PM   #3
cam_114
cam_114's Avatar
Here's some pics, the black rod is from the booster...
cam_114 is offline   Reply With Quote
Old 11-25-2012, 08:41 AM   #4
tard01
Thanks for the pictures, guys. Much appreciated.
It was too dark by the time i got home and not worth teh hassle of taking a light out to it (cant drive it, i ripped hte driveshaft out to replace the carrier bearing).
Going by memory, i think i might have to make a mount or adapter for it.
It seems your plungers/rods are different than mine, or you have an adapter i don't have or havent found.
I ordered this one with that plunger (notice it says picture may not be exact model)
http://www.drivewire.com/includes/se...tlIGJvb3N0ZXIu
but, i ended up getting one shipped to me that looks like this:
http://www.drivewire.com/includes/se...Ugd2FycmFudHku
a bit annoyed since i went out of my way to find a brake booster with that specific rod/plunger and i get the same one i had found elsewhere. oh well, will just have to find a way to make it work.
i didn't properly try yet, but maybe i can remove the plunger from teh brake booster and recycle the plunger i have from the master cylinder.
Old 11-25-2012, 11:47 AM   #5
S10Fan
Old Heap Driver
The best I recall......Manual brakes and power brakes not only use different plungers, the plungers are set a different angles for power vs manual. Manual brake plungers are at a straight line between the master cylinder and the pedal, power setups have the plunger going upward to the booster.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
