11-25-2012, 01:49 PM | #1 |
replacement springs
I need to replace the stock front springs on my 58 ( 2wd 1/2 ton) . Any and all suggestions on type of spring assemblies and where to purchase would be welcomed. The back bolt wore through the bushing and the hole in the spring is worn out to oval. I could replace just the main leaf but I am not sure if it would just be smarter to replace the whole assembly and know that it is all up to spec.
11-25-2012, 04:24 PM | #2 |
Re: replacement springs
A local spring shop should be able to make you new main leaves and rebuild the springs if you want to go that way.
one source in CT http://www.superiorspring.net/ LMC shows them for 229.95 ea for a price comparison http://www.lmctruck.com/icatalog/ca/full.aspx?Page=91
11-25-2012, 04:25 PM | #3 |
Hollister Road Co.
You could get away with just replacing the leaf. If you replace the entire spring you should do it in pairs.
http://www.eatonsprings.com/ has new springs. |
11-25-2012, 04:28 PM | #4 | |
11-25-2012, 10:53 PM | #5 |
I used to use Ferrara Spring in Western MA when I was down that way. They're probably OK but you might want to call first in case they were affected by the gas explosion. If I remember Springfield right they're several blocks away.
With springs that old you are gambling by just changing the main leaf. There are vast differences in metallurgy between then and now and you my find leaves breaking with a new main leaf that lasted for 54 years with the original. By having the springs built to order you can talk with the seller about using insulating pads, changing leaves, adding arch but reducing leaf count & etc to better tailor the truck's ride to your preferences. Be prepared though. Non-Chinese made springs and spring stock can be quite expensive and you may have to remind yourself the quality is well worth the price. Last edited by 1project2many; 11-25-2012 at 11:01 PM. |
11-26-2012, 03:08 PM | #6 |
Mr48chev, funny you should mention Superior Spring. When I was 17, I had a '51 1-ton with a broken right front main leaf. I gave Superior the old spring and they bent up a new one for me. It's because of this experience that I know you should always replace springs in pair. The truck always sat about 2 inches higher on the passenger side after that! Aside from that, I've always been of the school of thought that if one broke, you're probably not that far away from another one breaking. Definitely do them in pairs.
1971 Chevy K20 350/SM465/NP205 |
11-26-2012, 06:12 PM | #7 |
Talked to Superior spring today, they will have a set for me Wednesday.
Thanks! |
