Old 11-29-2012, 08:06 PM   #1
Woodnears
Need some help with a drive shaft.
Here's the story. I have a 68 shortbed that I have put a lt1 4l60e combo in. I plan to lower this truck and want to go with a two piece drive shaft. I need some pics of what carrier to use. Mine came with no such thing. The previous owner mounted the horseshoe carrier to a piece of angle iron behind where the carrier would normally be. I have the bracket for the round style carrier. Can someone post a pic of how this might work or any input on how to make this work. Round or horseshoe style, is one better than the other. Need help. I wanna drive this thing!
Woodnears is offline   Reply With Quote
Old 11-30-2012, 12:43 PM   #2
Woodnears
Re: Need some help with a drive shaft.
Ttt. I need to figure this out.
Old 11-30-2012, 12:55 PM   #3
dukcaln
dukcaln's Avatar
I can take a pic of my carrier, should be the same cause all you will need to do is shorten or extend one of the drive shafts, either the front piece or rear. the carrier will be the same and should mount in the same spot if measured correct. just find a 68 short bed truck that had a two pieve DL and take the entire thing and go from there. should not be that hard to find
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 11-30-2012, 01:00 PM   #4
dukcaln
dukcaln's Avatar
Here is mine, it should be the style you need. I also have another shaft with a slightly different carrier but either will do, since they were on my 72LB... carriers are the same.
SOLD 1972 chevy c10
Old 12-01-2012, 10:18 PM   #5
crazy longhorn
Fabricate till you "puke"
Pics can be decieving, but here goes...It looks to me that the rear shaft is a tad short? I saw that you had a vib issue in the driveline, just trying to help To check, you might run a "sharpie", across the splines, & pull the rear shaft, to see how deep the shaft is buried on the spline. You should not need more that 1" of slide on the center yolk, but should have a good 3 -3 1/2" of the spline buried. If you have her sorted out, disregard this post, & have fun playin crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-01-2012, 01:48 PM   #6
Woodnears
I think i got it figured out. Thanks to all who gave their input. I found the carrier bracket of my parts truck.
Old 12-02-2012, 02:36 AM   #7
dukcaln
dukcaln's Avatar
crazyL your spot on, I know it is short, I went with the one I bought from a local chevy guy and it ended up being short.... I measured my DL I took off and it is 3 inch longer than this one., so I am adding the TH400 yoke with a combination ujoint and installing.... according to my measurments it will be perfecr.... but I wont know until i get under there...
SOLD 1972 chevy c10
Old 12-02-2012, 10:34 AM   #8
Woodnears
Shouldn't your carrier be on the cross member as well? Mine was mounted on a piece of angle iron from the previous owner. I have since found the right bracket for the carrier and am in the process of putting it back together. I assume the angle iron is the in correct way
Old 12-02-2012, 11:43 AM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
As long as your angles are correct it doesn't matter how the center support bearing is mounted, as long as its solid to the frame. Front shaft parallel to the frame (unless to correct for more than 3* angle of rear shaft). If you need more than 3* up to 6* movement you need a double cardin style joint.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
