can some tell me what this is for ?
i have a chevy 355 that spits oil out of this hole (arrow pointing) can any one tell me what it is for ? thanks in advance
Re: can some tell me what this is for ?
do you know what year your block is ?
![]() Join Date: Feb 2005
Would that be where a bolt goes in that holds up the fuel pump rod in place so when you remove the pump the rod stays in place so you can remove the pump and also when you replace it?????????
John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
Those holes were used for the front motor mounts on the early small blocks. Not used for anything on the newer blocks but I think they just kept them there for backwards compatibility.
Anyway, that one with the arrow in your pic is open into the fuel pump push rod area on a lot of blocks and will leak oil unless it's plugged. Use a short 3/8"-16 bolt with some thread sealer ... just make sure the bolt is short enough so it doesn't hit the fuel pump pushrod. As a sidenote, that hole comes in helpful when replacing a fuel pump. You can stick a longer bolt in there (hand tight only) to hold the push rod from sliding down. |
thanks yea i wasnt sure why it was spitting oil out of there and the motor i pulled out of a 1978 z28 camaro
![]() Join Date: Aug 2011
Two bolt hoses are for air pump bracket. Just put short bolt in like ray mcavoy said.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
It is used as well to hold a fuel pump rod to install a pump. But it was as well used for the front motor mounts on the earlier models. Just get a short bolt and put some sealer on it
2004 Silverado Crewcab (Dark Spiral Gray) |
