Old 12-03-2012, 05:10 PM   #1
dmw319
Arrow How to Adjust Panhard Bar?
So I am installing my 3" rear/1" front drop springs and shocks (w/relocation brackets) from ECE this week and an adjustable panhard bar with new bushings since mine was shot I figured I might as well upgrade the whole bar.
Question, do I install the bar along with my springs/shocks and THEN adjust it? Or do I wait until after I install the other components and let the suspension settle and THEN install it? And is there any science to adjusting it other than making it the proper length and bolting it on?
Thanks in advance!
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 12-04-2012, 01:33 PM   #2
dmw319
Re: How to Adjust Panhard Bar?
i know somebody must know this!
Old 12-04-2012, 02:56 PM   #3
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Easy peasy! Install it when you install your other lowering components. Measure from the back of your hub to a common spot on your frame for each side and do your best to center it. Depends on what type of panhard bar you have. Mine has to be removed from the axel side to adjust it which.makes it kind of a pain. I had to use tow straps to "position" the rear end and then reinstall the bar. Other panhard bars just adjust at a coupling like your tie rods. Your fresh new coils will settle, so you'll want to check your measurements after 6 weeks or so. Hope this helps!
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 12-04-2012, 03:04 PM   #4
dmw319
ive got the springs/shocks out. should i put it in before or after i install those?
also, i got the adjustable bar from ECE.
Old 12-04-2012, 03:26 PM   #5
stevencvn72
Kill Bill...et
Put your new springs and shocks in first and set the truck back on its feet (or on jack stands under the trailing arms) to see where your at. Either way, you'll need to jack it back up to pull your u bolts to install the bracket for the bar. There'll be some trial and error, so hang in there.
-Steve
I Grease
'67 Chev stepper
Old 12-04-2012, 03:28 PM   #6
dmw319
pull the u-bolts for the bracket? i didnt think there was a bracket with the bar. thought it was just a beefed up bar.
I didnt get the "Super trac bar" just the standard one.
Old 12-04-2012, 03:37 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Does your adjustable trac bar have a swivel at BOTH ends or just one end?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-04-2012, 03:40 PM   #8
dmw319
just one im pretty sure
Old 12-04-2012, 03:47 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Bummer. If you had the one that swivels at both ends, you just install it, and twist it forward or backwards to center your rear left to right. Since it only swivels at one end, you need to center your rear end first, adjust the bar, and then install the bar, as described in post number 3 above. Not a big deal, just takes longer. The dual swivel allows you to do it in a matter of seconds.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-04-2012, 03:51 PM   #10
dmw319
thanks for the tip!
Another question, I have the ECE shock mount relocation brackets but Im not 100% sure which way they go on and dont want to install them in the wrong direction. In this picture (from ECE site) this is showing the drivers side correct?
Old 12-04-2012, 03:57 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Yes, that is correct.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-04-2012, 04:00 PM   #12
69gmcc10
69gmcc10's Avatar
Install everything (shocks springs and bar), get it on the ground measure the backing plates of each side and make adjustments on the panhard bar until the rear is centered under the truck.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 12-04-2012, 04:04 PM   #13
dmw319
backing plates?
Old 12-04-2012, 04:20 PM   #14
69gmcc10
69gmcc10's Avatar
for a lack of a better explanation they are the inside of the brake, the round part that bolts to the end of the axle and all the brake hardware mounts to.
Old 12-04-2012, 04:22 PM   #15
dmw319
like the inside edge/rim of the drum brake?
Old 12-04-2012, 04:24 PM   #16
69gmcc10
69gmcc10's Avatar
the round metal housing the brake line attaches to the drum fits around.
Old 12-04-2012, 04:25 PM   #17
dmw319
yep ok. were talking about the same thing. so measure from there to a common place on the frame? just wana make sure i do this right!
Old 12-04-2012, 04:27 PM   #18
69gmcc10
69gmcc10's Avatar
you got it!
Old 12-04-2012, 04:32 PM   #19
dmw319
i learn by seeing.. so if anyone has a picture of the place where they measured, thatd be great. although i think ive got
Old 12-05-2012, 05:24 PM   #20
weever82
weever82's Avatar
subcribed
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
