crossmember question?
I am sure this is been asked on here a bunch, but I am doing a 5 front,7 rear drop on my 69 C -10 and was wondering why the trailing arm crossmember needs to be moved forward a inch?
Thanks for any help Posted via Mobile Device
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: crossmember question?
It doesn't.
![]() Join Date: Mar 2010
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
![]() Join Date: Mar 2011
I'm no expert, but I would also say no. Did a 5" rear drop on a 67 and didn't move anything...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
I agree with the other guys but I wanna complicate the situation. I saw this thread earlier and have been thinking about arcs and suspension travel all day. If the truck is dropped with springs the wheel will move farther forward in the wheel opening as it is lowered. The last thing you'd wanna do is make it even worse by moving the crossmember further forward. I think you'd wanna move it back if anything. Some of the aftermarket crossmembers offer adjustability if you wanna go to those lengths so it does hold some merit. The first thing I'd do is knock out the rivets of the trailing arm brackets on the crossmember and flip them upside down to put the forward end of the trailing arm higher in the truck to correct the geometry. If you wanna be anal, mark the centerline of the rear wheel opening and adjust the rear suspension so that the rear wheels are centered. In short, you dont have to touch a thing (did I mention c notches?) to drop it that low in the rear but you can if you wanna take it a step further.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#6 | |
Thanks for the responses, i am still digging into this myself, but all thoughts help
Thanks guys Posted via Mobile Device
I have never seen anyone move it just a lot that replaced it with some kinda aftermarket one tho.
