12-04-2012, 09:20 PM | #1 |
Can My 305 Tow?
Ive got a '83 reg cab stepside with a 305 and th350 tranny. Would this truck be able to tow a 3200lb car(Corvette) on a car trailer? I dont plan on doing much towing but I am in the military and will be moving soon.
12-04-2012, 09:45 PM | #3 |
Re: Can My 305 Tow?
Stopping will be a challenge. Please add a brake controller to the truck and make sure the trailer has electric brakes.
Check your hitch over real well and make sure it is rated for the load you will be pulling.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-04-2012, 10:11 PM | #4 |
Re: Can My 305 Tow?
^^ +1
Before you ever ask if your truck will tow something. Ask if your truck can STOP what you want to tow!! Getting going is the easy part.. Stopping is the issue!! When in doubt, don't do it! |
12-04-2012, 10:17 PM | #5 |
Re: Can My 305 Tow?
Wasnt sure if the 305 was enough power to tow anything. Anyone know how much my truck should be able to tow? I understand the potential stopping issues-anything I can do to help with that or is a brake controller my only option?
12-07-2012, 09:47 AM | #6 | |
Charlie Daniels w/ a Tq Wrench
Re: Can My 305 Tow?
One of our trailers has surge braking, a retired U-Haul trailer actually, which was beat on for years as a rental, and now beat on by us, still works wonderfully. Sure it's annoying at times, but it always stops fine when needed.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
12-07-2012, 10:40 AM | #7 | |
Re: Can My 305 Tow?
Dad and I built that trailer in 1967 and it is still in use. Getting a fresh coat of paint as we speak. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-07-2012, 10:43 AM | #8 |
Re: Can My 305 Tow?
This, however, is not recommended:
I wasn't going far but it was a bit more than I was comfortable with. I won't do it again. I should reiterate my truck is a V6 rather than a 305. K
12-07-2012, 11:28 PM | #9 | ||
Re: Can My 305 Tow?
For what it's worth, i did try towing last year. It was a light 1900lb car and uhaul trailer. Admitedly, the 1/2 supported and handled the weight pretty good (although moving the weight was a different story). Did not have a weight distributing hitch either. But i feel that if i had used a 3/4 or 1 ton it would be handled even better. It's a case of you don't know what your missing if you have not had the chance to compare. i thinks it's the kind of thing where with a 3/4 or 1 ton, you don't even know the trailer is back there. With a 1/2 ton you know. Even if it does an ok job and towing it. |
12-07-2012, 11:47 PM | #10 |
Re: Can My 305 Tow?
I've been towing for a few years with my C10, 305/SM465/2.73. Biggest issue is my trailer has no brakes, please use a trailer with brakes.
The only time I had an issue with stopping was when I towed an Explorer, 6000lbs combined towed vehicle and trailer. Not cool when you get pushed thru a stop sign, but made it to the destination without incident. |
12-07-2012, 11:52 PM | #11 |
Re: Can My 305 Tow?
I tow all the time, suburbans, trucks, scrap with my dads 84 seen here with no trailer brakes at all guess I'm just cautious and look ahead.
12-04-2012, 10:18 PM | #12 |
Re: Can My 305 Tow?
305 explained- the 305 is the engine designed to do the work of a 350 but for less gas.
If a dodge caravan can tow a boat then why can't a truck? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-04-2012, 10:24 PM | #13 |
Re: Can My 305 Tow?
i would say the important question is what diff gear do you have? This is more important than 305, which technically could do the job.
12-04-2012, 10:28 PM | #14 |
Re: Can My 305 Tow?
Not sure what diff or gears do I have-how can I find out?
12-05-2012, 12:01 AM | #15 |
Re: Can My 305 Tow?
Do you have a spid sticker under the hood on one of the fenderwells?
And/or what is your gvwr rating on the driver's door? In short, yes it can probably tow it, but it might be slow. Also, 1/2 ton really isn't the best thing when towing a car trailer, but this sounds like a one-time deal. |
12-07-2012, 08:16 AM | #16 |
Re: Can My 305 Tow?
12-07-2012, 09:16 AM | #17 | |
Re: Can My 305 Tow?
Desert |
12-05-2012, 01:01 AM | #18 |
Re: Can My 305 Tow?
About 10 years ago on a very hot July day I help out a buddy who was in a bind and needed his Corvair towed 150 miles. All I had was my '86 C10 with a 305, sm465 4-speed and 3.08 rear. The trailer was homemade and very heavy (about 5000 lbs and the car about 3000), we had NO trailer brakes and just a universal frame mounted hitch on the truck. I was in no hurry which was good because top speed was about 50 on flat roads and about 25 on hills. The truck did great and the 305 ran like a champ! If your truck is in good mechanical condition, you drive carefully and are familiar with the route you're taking you should have no problems.
12-05-2012, 01:27 AM | #19 |
Re: Can My 305 Tow?
You can tow with just about anything. It might not be safe or efficient, but it can be done.
12-05-2012, 01:41 AM | #20 |
Re: Can My 305 Tow?
12-05-2012, 08:11 AM | #21 |
Re: Can My 305 Tow?
This was my regular race rig for many years (car weighed about 3600 lbs at that time).
Also used this when I moved from Detroit to Phoenix. I just echo the comments above regarding trailer brakes: stopping is way more important that going. K
12-05-2012, 09:25 AM | #22 |
Re: Can My 305 Tow?
Stopping is the biggest issue.
Right now all I have for a work truck is a Mazda B3000 and occasionally I have to haul my 16' haulmark with no electric brakes. Good thing it's a stick. It hauls it just fine but not all that fast sometimes. I don't load the trailer anywhere near it's capacity and make sure whatever is in it gives me the proper tongue weight. Now as far as the brakes go that's another story. It has nowhere near enough braking power. I'm sure I make everyone mad around me mad driving so cautious. I only use it local and wouldn't drive it up to highway speeds without electric brakes. If I had a 1/2 ton and the trailer had electric brakes I wouldn't hesitate to move your car. |
12-05-2012, 10:23 AM | #23 |
Re: Can My 305 Tow?
Lower gears----i.e., 3.73, 4.11 etc. can help with compression braking.
i guess the big issue is does the trailer have brakes? |
12-06-2012, 05:46 AM | #24 |
Re: Can My 305 Tow?
we towed a 12k car trailer truck combo 250miles with my 305/700r4 2.73. It'll tow anything just make sure you watch your gauges in case you have a cooling issue. Plan your stops.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
12-06-2012, 06:05 AM | #25 |
Re: Can My 305 Tow?
Great thread! Also my favorite view.
