![]() Join Date: Oct 2007
stock mirror holes
i bought new mirrors for my truck a while ago. i went to install them and the mirror brackes/arm holes don't line up. anyone using stock mirrors and can measure where the holes should be on the body it would be a great help.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
Re: stock mirror holes
![]() The vertical lines are measured as if the front of the cab were against a wall measuring back. Horizontal is up from the ground with the top of the frame being about 10. I've looked all through this factory assembly manual and this is the best I could come up with. Posted via Mobile Device Posted via Mobile Device |
thanks for that i just got home from the garage. i installed the mirors using the measurements my friend got off one of the trucks sitting in his father in laws field. i only had to drill one hole and weld 3 up. gota love what past owners did.
If you look on the inside of the door you can see the three holes already cut into the bracing just drill to the center of all three.
mine don't mount to the door they mount to the cowl area. i should have mentioned my truck is an ad model not a tf model.
Look under the dash there should be welded in braces with the holes punched in them.inside the cowel.
that would help if there wasn't holes already drilled and filled with crappy weld but the previous owner/owners. but i got them in the right spots i think. well close enough. thank everyone.
#8 | |
