Old 12-08-2012, 07:52 PM   #1
melhilburn
melhilburn's Avatar
broke my driver side blinker return
pushed down too hard on my blinker and now it won't automatically return when the steering wheel is turn clockwise - How difficult is this to fix??
melhilburn is offline   Reply With Quote
Old 12-08-2012, 08:05 PM   #2
MacsGTO
Re: broke my driver side blinker return
Not really hard just time consuming. Steering wheel pulled off with a wheel puller, remove shaft nut and locking clip using a lock plate tool. After that just slide your signal switch out unplug it from the lever and reverse the process. It won't return because the cancel cam tab is more than likely broken which is part of the signal switch.
MacsGTO is offline   Reply With Quote
Old 12-09-2012, 12:21 AM   #3
Captainfab
60-66 Nut
This is likely the part you need to fix the problem. You will have to access the turn signal switch in the column to replace it.
http://www.classicparts.com/1964-66-...tinfo/53-586B/
