12-10-2012, 08:40 AM | #1 |
ChiefRocka Split Break Question
Chief,
I have a date or three with Ol John Lee (64 C10 SBSS) over the Christmas Holiday. On tap is: 1. Full front suspension rebuild. 2. Dual Drum/Drum Manual brake conversion 3. Intake manifold gasket/oil leaks One question. On your Dual Break Master Cylinder conversion thread, you plugged one outlet on the passenger side front tee fitting. Was the plug you used a special plug with inverted fitting shape to the face or a simple brass pipe plug? |
12-10-2012, 08:54 AM | #2 |
Re: ChiefRocka Split Break Question
I found my plug at napa. Nothing special about it.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-10-2012, 09:24 AM | #3 |
Hollister, CA.
I used an inverted flare plug, easily available as SB70 mentioned.
An 1/8 pipe plug might work as well ....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
12-10-2012, 07:52 PM | #4 | |
sam |
12-10-2012, 10:31 AM | #5 |
Thanks. I'll see if NAPA has the inverted flare plugs. Regular parts houses don't seem to either have them or know what they are....
12-10-2012, 11:19 AM | #6 |
I gotta recheck my lines. I know I have 1/4 up front for the front cylinders and there is 3/16 from either side of the rear T to the rear cylinders.
If the center line from the passenger front t to the passenger side rear t is also 1/4 line, I think I'll just eliminate the passenger front t all together - dispensing with the plug and all the extra places for leaks to start at that corner. |
12-10-2012, 12:10 PM | #7 |
I did this a few weeks ago on my 63, and NAPA had the correct flare type plug in stock.
Joel |
12-10-2012, 12:36 PM | #8 |
Cool. I checked the thread sizes on the front and rear flexible hoses. It confirms the front lines are 7/16x24 to connect up to the original 1/4" front hard lines.
The rear hose is 3/8x24 which means both rear hard lines to the wheel cylinders are 3/16" size as well as the line between the right front Tee and the rear hose. So, I suspect I'll simply eliminate the entire right front tee and run 1/4" line all the way to the back. I can simply reduce at that fitting to hook up to the smaller rear brake hose fittings. It'll give me fewer joints over all and a bit more flexibility in running the lines to the rear. |
12-10-2012, 12:39 PM | #9 |
Now I just gotta crawl under to measure all the lengths and get a count on fittings, clamps, etc. And root around in the tool box for the disk that goes on my tubeing bender sized for 1/4 and 3/16 lines. That rooting around could be the longest part of this job!
