Old 12-10-2012, 08:47 AM   #1
mking
Shift Indicator adjustment
Hello Everyone. I'm new to the site. I've learned a lot about my truck by just reading other questions and answers. you guys are a wealth of knowledge.
I have a question. I've seached the board and looked at the other threads about the shift indicator. I've seen other pictures that look similar to mine. They all say to adjust the linkage. I've tried that. No matter how long or short I make the linkage, it doesn't change the pointer on the column.
I've even disconnected the linkage and it is still off to the left.
Is there an adjustment in the column?
I don't thinbk this is the original column. Could that have anything to do with it?
Thanks in advance for all the help.
mking is offline   Reply With Quote
Old 12-10-2012, 08:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Shift Indicator adjustment
Where is the pointer when the trans is in neutral?
LockDoc
Leon
Old 12-10-2012, 10:46 PM   #3
jondancer
I also have this problem
jondancer is offline   Reply With Quote
Old 12-10-2012, 11:34 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
What year truck and what transmission does it have. It looks like the indicator may not be a match for the pointer. If you have a 350 or 400 turbo trans, then I think you should have a L1 position on the indicator as well as a L2. When I have a chance, I will look at mine. I have a 72 with a 350 trans and I think it has a L2 qnd a L1.
TBONE1964 is offline   Reply With Quote
Old 12-10-2012, 11:48 PM   #5
mking
It's a 70 C-10 with a 350 engine and t350 transmission.
When the transmission is in neutral, pointer is on the R.
In the process of trying to figure out what to do, I disconnected the rod to the transmission at the column. The pointer would just past the D.
Old 12-10-2012, 11:59 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
The L1 is hard to see in the photo. Anyway my point is that the indicator may not match the pointer even if they both have the L1. I am fairly certain that my 72 has a different style indicator.
Even with the linkage disconnected, the pointer should point to park when the shift arm is pushed up as far as it will go (to the park position). Does this make since? It sounds like know matter how you adjust it, it does not line up in park? I don't believe there is any adjustment in the column but I may be wrong.
Old 12-11-2012, 12:08 AM   #7
mking
It could be something wrong with the pointer. I've thought about taking the screw out and moving it over to where it lines up.
I think it may not be the original column. The paint is not the same as the dash. It's close but not the same.
There is another issue with the shifter also. It is VERY HARD to pull the shifter up to get it in and out of Park. Seems like there is heavy grease in the column.
Old 12-10-2012, 11:46 PM   #8
leddzepp
Moderator
leddzepp's Avatar
There is an L1 on his indicator.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-11-2012, 12:01 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Here is how to adjust. Put it in park. Loosen the linkage retainer. Move the gear shift lever down to the center of Park. Re tighten linkage retainer (this is easier with 2 people) This is the only way I know how to adjust it. Maybe someone else has a suggestion as to what the problem might be?
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-09-2013, 08:38 PM   #10
buckskins4ever
buckskins4ever's Avatar
Thumbs up Re: Shift Indicator adjustment
this is good advice. You really do need two to hold the column in place while tightening. Your shift indicator is correct.
I had the same setup in my 72 until switching transmissions.
buckskins4ever is offline   Reply With Quote
Old 03-09-2013, 09:47 PM   #11
LockDoc
LockDoc's Avatar
Before you try the following there are two things you need to do. One is to check the shifter pointer and make sure it is in the correct position. There is a screw in the back and two little plastic hooks/locators/tabs in the front. Make sure that the hooks/locators/tabs are not broken off, or maybe they are not down in the slot which would allow the front of the pointer to move back and forth. The second thing is to spray some PB Blaster, Liquid Wrench, or something similar (not WD-40) into the steering column, where the shift lever goes in. Don't be afraid to give it a good dousing. After you spray it pull the shift lever up toward you and push it back down toward the dash. It should move up and down a couple of inches. Do this 4 or 5 times. This will help free up any sticking in the shift lever tube. The reason the shift lever moves up and down is because it should be pulled back towards you to shift it into and out of the park position.
After you have done that open the hood and loosen the adjustment bolt at the top of the rod that connects the transmission and the shifter arm on the steering column, crawl under the truck and manually shift the transmission into Park. Hold it in Park while someone puts the shift lever in the park position up above, then tighten the adjuster bolt back up. This should correct your problem.
Be sure and block your wheels before you start this.
LockDoc
Leon
Old 03-09-2013, 11:31 PM   #12
dmw319
LockDoc
Do you have a picture from under the hood showing the position of the lever on the column when it is in park? I have my shift rod completely discconected from the column and when I have the pointer on "Park" it seems to be in the second tab over from the right (reverse) and not the farthest to the right over the hump (park) when I look from under the hood.
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 03-10-2013, 12:46 AM   #13
LockDoc
LockDoc's Avatar
The procedure in the first part of my post should take care of that problem. Usually the reason it won't go over the hump is because the shift lever won't move up and down.
LockDoc
Leon
Old 03-09-2013, 08:10 PM   #14
dmw319
BUMP i have this same issue. ever get it figured out?
Old 03-09-2013, 11:58 PM   #15
dmw319
This answered my question about the pic:
http://67-72chevytrucks.com/vboard/s...gear+indicator
Seems like I just have it too far over! Thanks.
Old 03-10-2013, 01:41 AM   #16
tcoop68
tcoop68
tcoop68's Avatar
Lockdoc answer is the best way , as for the stiffness in your lever take the time to tear down the column and clean and relube that will fix it . It is probley worse when it's cold that's because the grease is thicker.
tcoop68 is offline   Reply With Quote
Old 03-10-2013, 11:00 AM   #17
mking
I think we have decided the column is not original and might be a standard column that has been modified
Old 03-26-2014, 01:40 PM   #18
1966
have this exact same issue, bookmarking for rainy day project
1966 is offline   Reply With Quote
Old 03-26-2014, 02:43 PM   #19
LockDoc
LockDoc's Avatar
OK, let us know if it works for you, or if you have any additional questions.
Thanks,
LockDoc
Leon
Old 03-26-2014, 02:59 PM   #20
1966
Thanks,
LockDoc
Thanks LockDoc. Why would one not want to use wd40? still learning here...
Old 03-26-2014, 07:00 PM   #21
1966
Here's some photos of my shift indicator in its various positions; I do have to pull the shift handle FORWARD and RIGHT to engage so I know at least that part is working.
confused about "loosen the adjustment bolt at the top of the rod that connects the transmission and the shifter arm on the steering column"; is it this thing:
thanks for any help, sorry for dumb questions still getting to know this beast
Old 03-26-2014, 08:15 PM   #22
LockDoc
LockDoc's Avatar
WD-40 is not a penetrating oil it is a Water Displacement product, thus the WD designation. The 40 stands for the 40th formula tried that actually worked (for what I don't know...
Looks like someone has replaced your stock parts with a Heim joint at that location.... The adjustment instructions in this thread will not work for that.
LockDoc
Leon
Old 03-27-2014, 12:37 AM   #23
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Is it possible that the collar the that the letters are mounted to has moved to the right slightly? Just a thought.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
Old 03-26-2014, 09:14 PM   #24
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
You could try to tighten the he in down. If you can't go any further then you can probably cut the threads off some. Let us know how it goes
FRANKENSTEINC10 is offline   Reply With Quote
