Need Blazer Tub Pics!
Does anyone have close up shots of the area behind the front seat on a Blazer tub? Underneath and inside would be great. Isn't it stepped there? Is there a replacement panel for that area? Is the front floor board the same as a truck? Thanks in advance!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
![]() Join Date: Feb 2005
Re: Need Blazer Tub Pics!
I got a couple pics. I'll have to search for them tho..Heres a couple from when I put a truck floor in my Blazer..
A few more
Thanks! So the Blazer floor isn't the same but a truck floor will go in? Is that verticle piece between the floor and bed available in the aftermarket?
If I remember correctly the floor will work but the area right at the point where it meets the vertical frame at the start of the bed floor will need some work. As far as the vertical piece I dont think it is being reporduced but is easly made. I had to make mine along with the mounts that hold the frame bolts.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
Just a nother gear head
the fllor are the same to just behinde the seat mounts then thats where they are different. the truck floor works great just needs to be modified to make the lip at the vertical raise to the bed area. that vertical piece isnt available but is easly made. for the most part all truck parts work in the blazer with some or no mods depending on the peice. i think there is some pics from underneath in my build thread link in my sig.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
I am doing the same as you, I purchased a floor for a cab and going to cut to fit, it looks as I be cutting about 10 inches of the back,basically where the gas tank would fit in the cab. I fabricated the vertical piece, just enough of the old part I was able to get dimensions.
Here is some pictures I still am not good at posting things.
Here I think I got these pic posted
David,
Where did you get the wheel dollies? That's kickin!!! Will need something similar for mine as she is a bare to move around by oneself LOL How much weight can these support? Thanks! Pat |
