Another Day, Another Dollar
how much current draw from a 10,000lb winch?
hey guys,
I've mounted a winch on my truck and it occurred to me that there is no fuse on the winch. I find this terrifying!! I want to put a night switch as well as an inline fuse in front of the winch, trouble is I'm not sure how big of a fuse. I actually only have a 5000 pounder on the truck right now but its temporary until i find something bigger for the right price. There is also a 75 amp battery isolator on the truck right now, should i be getting a bigger one? thanks, spencer
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Re: how much current draw from a 10,000lb winch?
Depends on the brand and model.
lets say its a warn m10,000. that is probably what I'll end up with
#4 | |
Any electric winch you are looking at will require around 400 amps at 12 volts for maximum pulling force. As far a a 400 amp fuse, good luck. A battery dicconnect is always recomented as to prevent a fire if the winch solenoid contacts get stuck closed, and have a good B/C fire extenguisher on hand. If all this scares you, better look into a Milemarker hydraulic unit. It uses the power steering pump or a external driven pump for power. Or better yet, if your vehicle transmission will support it, a power takeoff unit. Both have a 100% duty cycle unlike the 10% to 20% of a electric winch.
