12-13-2012, 09:20 PM | #1 |
71 GMC/Chevy Build
This is the POS on the day I purchased it. Thought I would clean it up a bit, throw in a new motor, and drive it for work at my cabinet shop. A week later it was a frame on my shop floor. Project took about a year to complete. Will post photos daily of the build.
12-14-2012, 10:12 AM | #2 |
Re: 71 GMC/Chevy Build
Almost ready to take the body off the chassis. Life for this truck started out with a drop down tail gate. I have found 5 bakers doors. Should be able to make 2 good ones. Lots of rust at the front rocker / floor area. Found a trashed ambulance and salvaged the firewall / floor assembly. This will be much easier than patches. Will replace the wood floor with some new marine grade plywood after the mini tub (2.5" ) is complete. The Toyo tires should fit now with no problem. Also found a front 71 chevy clip. Flawless condition.
12-14-2012, 11:36 AM | #3 |
Junior Member
Looks really solid.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-15-2012, 10:43 AM | #4 |
Mini tub is complete as is the new marine grade plywood rear deck. Firewall and floorboards have been swapped from the ambulance doner. The front suspension is complete with drop front spindles and new coils. Next will be the dry fit of the new engine and transmission. The body comes off and goes on like a yoyo. I feel like I may reach indy 500 pit times with it soon.
12-15-2012, 01:58 PM | #5 |
Ridin' Dirty
Looking forward to more!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
12-15-2012, 02:01 PM | #6 |
Nice work! Those mini tubs are perfect.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-16-2012, 01:25 AM | #7 |
The engine and transmission fit nice. I do like the 3/4 length headers. Had to move the transmission crossmember for the 700R4. 20/20 hind sight, I wished I had used the reliable turbo 350 or 400 and added a Gear Vendor electronic overdrive. I like the gear reduction of the 700R4 but hate the shift patterns. I will never get used to it. With the swap of the firewall and floor from the ambulance came a couple of benefits. The ambulance was a factory A/C truck so the new dash has the vents as my original was not an A/C. The second benefit is the larger transmission tunnel with the bolt in cover. Sure made life easy. At this point I also decided to go with the aftermarket fuel injection.
12-16-2012, 09:50 PM | #8 |
Engine is complete. It is a 406 CI small block with SCAT crankshaft and rods, Speed Pro pistons, Comp cam, World Products heads with Harland Sharp roller rocker arms. Nothing crazy just a strong high torque engine so I can pull my selection of vintage trailers. The fuel injection is Accell and was kind of a pain in the ass to tune. Once I had it perfect though I indeed like it. I had to tig weld an AN male fitting to the fuel tank for a return line and at first the wiring was a bit overwhelming but with some studying it all came together. The fuel milage is very good and with the 3:73 gears and overdrive it cruises down the road 75 running very low RPM. I cool it with a dual Spal fan setup controlled with a CenTech fan control system. I can adjust at what temprature I want the fans to come on. I also used an aluminum Howe Racing radiator.
12-17-2012, 11:21 AM | #9 |
Nice burb!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-17-2012, 10:26 PM | #10 |
So the body comes off for the LAST time. All components are sandblasted and painted. New seals, bearings and other parts. Everything is new. Swaped the 3:08 gears for a set of 3:73's. Chassis is basically stock with the exception of dropped spindles and coils up front and I removed the coils in the rear and replaced them with air bags. Fabricated a mount for the compressor and air tank. Ran the fuel lines, brake lines, and PS lines. Finished the ignition wires and love the Bill's HotRod brackets. Finally a complete roller. Time to mount the body and start cutting things up.
12-18-2012, 12:28 AM | #11 |
Hello from the wet side of the state. I would have been happy with your rust.
Travis 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
12-18-2012, 08:07 PM | #12 |
Junk Yartist
Man, that's nice!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
12-18-2012, 08:13 PM | #13 |
Great Job so far, love GMC burbs. You kept things simple and that suspension setup is going to provide real-world driving performance, well done.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
12-19-2012, 08:40 PM | #14 |
Lookin good, welcome to the board!
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
12-20-2012, 12:26 AM | #15 |
Prestige Worldwide
Subscribed.... Looking good!
12-20-2012, 10:07 PM | #16 |
Body goes back on for the last time. I may have to loosen a few mounting positions to add shims for the right reveals. You can see the 3rd door from a doner suburban. I also salvaged the bakers doors from the same truck. The doner truck was at a wrecking yard out of town and in not terrible shape. 4x4 at that. I went back a week later thinking I would drag it home for a future project. They said I was a day late as it had been hauled to the crusher.
Thought I would throw in a photo of my other truck. This is my 71,000 lb full remote RC truck. Forward, backward, steer, and operate from outside the truck. Sometimes I feel guilty calling it work. Any way, back to the suburban. Lots of body work left to be done. Some previous nuckle head did a piss poor job with the patch panels. ( those photos are for another time ) |
12-20-2012, 11:11 PM | #17 |
Welcome to the board. Very nice work..
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 Shawn |
12-27-2012, 08:53 AM | #18 |
67-72 parts collector,…
Great burb project!
12-27-2012, 10:07 AM | #19 |
Thank guys, now that the holiday season will soon be at a close I will find more time to post additional photos.
Posted via Mobile Device |
12-27-2012, 11:59 PM | #20 |
Here are a few shots of the crap work someone else previously left me with. From the looks of the back sides it was sometime in the not to distant past. We will cut most of the bad areas out ( my buddy Jim does amazing work ) then welded in new sections. This should last a while.
12-28-2012, 12:04 AM | #21 |
Here are a few photos of the new panels. The suburban is finished of all welding and sitting on stands ready for additional body work and primer. I still wounder to this day how the roof was damaged above the rear door.
12-31-2012, 04:57 PM | #22 |
A320 Pilot/USAF Retired
Nice work!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-12-2013, 11:47 PM | #23 |
Hotrodchevy
looking good
2017 1500 CREW CAB GMC 1997 C1500 Chevy 1971 CHEVY CHEVELLE SS 402BB : 1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816 My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650 |
01-23-2013, 12:09 AM | #24 |
Base coat and clear coat complete. Sanded and buffed. Next up fitting of the doors, fenders, and hood.
71 Chevy Suburban build 71 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=556132 80 K10 http://67-72chevytrucks.com/vboard/s...d.php?t=559565 |
01-23-2013, 12:11 AM | #25 |
Hanging the doors
