Old 12-14-2012, 05:47 PM   #1
72c10projectc
72c10projectc's Avatar
v8 and 6cyl driveshaft length
Is there any difference in length?
72c10projectc is offline   Reply With Quote
Old 12-14-2012, 06:47 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: v8 and 6cyl driveshaft length
Yes, the V8 smallblock vs the inline 6 (assuming same trans), will be 3 1/2" different in lenght. That is pluss or minus 1/8", & figured on original factory mounting points. It is best to do your own measure, do to the age of the truck.....you have to be sure that it has not been swapped before, with missmatched parts crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-14-2012, 08:34 PM   #3
72c10projectc
Does 79.5" sound right? For a v8 4spd
Old 12-14-2012, 09:08 PM   #4
crazy longhorn
As said, you need to do the measure....check with your local driveline shop, so you get it right on I remember ,1 time I cut a 2x4, 3 times....and it was still too short? Could not weld that back together crazyL
Old 12-14-2012, 09:12 PM   #5
72c10projectc
Got under and measured 79.5 so I was just wondering what a stock v8 manual trucks drive shaft was
