Old 12-14-2012, 08:42 PM   #1
yellowGT
yellowGT's Avatar
how does the ammeter work?
I have been wondering why mine doesnt work here lately. I everything works as far as the gauges but thats because the cluster harness is plugged in right? Does the ammeter work different because i noticed it has tw0 prongs on the back of it. HELP me out.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 12-14-2012, 09:12 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: how does the ammeter work?
As I recall there is a little dinky P.I.T.A. fuse in a small rubber connector behind the battery. I want to say it is in a brown wire.
It has been a while since I replaced it though.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-14-2012, 09:26 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a few threads to read. They will answer your questions.
...........http://www.google.com/custom?domains...D%3A1%3B&hl=en
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-15-2012, 10:29 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Ammeter works in series to voltage. That's why you have two wires -incoming 12vdc and outgoing 12vdc.
Mine would not work on my 68. First I made sure this ground clip was installed. I also replaced the engine to cab ground strap behind the drivers side head, installed a ground strap from engine to frame, cab to frame, bed to frame and one on radiator support. Basically you want to create a good ground back to negative battery. I got rid of a lot of all my gremlins, head lights work better and ammeter works great now.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
