Old 12-17-2012, 12:58 AM   #1
MacsGTO
Please don't flame me but I'd like to ask...
When converting to a BBW why is cutting and welding such a large section necessary? It seem like you could cut out the window size and roll the lip so that the seal attaches and then install the window. It sounds soooo simple and if it was I know everyone would be doing it that way. I'm just curious as to what I am missing that it's not being done that way. Thanks for the lesson that is about to follow.
MacsGTO is offline   Reply With Quote
Old 12-17-2012, 01:41 AM   #2
B_Bob
Re: Please don't flame me but I'd like to ask...
I don't think the problem is to do with the outer skin as much as the inner skin. It is made to fit only the small window. If you have the tools and skills to re-work that metal, then you would be in business, but it must be easier to source a BBW doner and weld it in.
B_Bob is offline   Reply With Quote
Old 12-17-2012, 03:28 AM   #3
oem4me
Correct. The inside panels at the rear of the cab are not the same. not even close.
Old 12-17-2012, 03:45 AM   #4
bk2life
Granted no-where near the same truck (it’s a chevy though.. ) but here when I did this chop you can see the outer panel removed, and the inner panel -very similar though for explaining your question a bit more.
bk2life is offline   Reply With Quote
Old 12-17-2012, 10:27 AM   #5
MacsGTO
Riddle solved, thanks a ton guys. And a picture is worth a thousand words.
I would have never guess that they would be so far out of alignment.
