Old 12-18-2012, 01:29 PM   #1
jks67ss396
airbags on slightly raised C10
Hi guys
Im looking at having Ricky at quality air rides make me a set of custom airbag cups to get my 71 C10 sitting at just slightly over stock (1-2").
He said that since he doesnt have a truck there to measure that i would have to get under my truck and unbolt everything and measure it out. Problem is that i sorta need my truck driveable at this moment.
Have any of you guys had custom airbag cups made? Or do any of you guys happen to know the distance from the frame to the lower control arm (for the front) and the distance from frame to spring pocket on the trailing arm in back?
Seems like this cup would be pretty tall... on the order of 5+ inches?
Obviously, im very new to this airbag stuff so any help is greatly appreciated!
jks67ss396 is offline   Reply With Quote
Old 12-18-2012, 11:45 PM   #2
jks67ss396
Re: airbags on slightly raised C10
bump
thanks guys!
Old 12-19-2012, 02:59 PM   #3
jks67ss396
bump... is this in the wrong section?
thanks
Old 12-19-2012, 03:24 PM   #4
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Maybe the mods could move this over to the suspension section. I don't see where adding taller cups would be dififcult. A taller cup on the bottom of the bag on the lower "a" arm and taller cup on the top of the bag in the rear. I don't really have any measurements for you though.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 12-19-2012, 07:11 PM   #5
jks67ss396
thanks for answering!
im really hoping someone had done these measurements at one time or another
thanks!
Old 12-19-2012, 08:58 PM   #6
Square_78
Square_78's Avatar
Well I've seen bagged trucks without drop spindles and 3" cups and they sit up pretty high almost stock height. Maybe try a 6" lower cup and see what happens. You can always trim some off or add a bigger cup. Only one bolt holding the cup to the bag. Easy to swap out.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-19-2012, 09:22 PM   #7
jks67ss396
that makes sense for the back.
as for the front... ive been thinking and looking at this:
http://www.67-72chevytrucks.com/vboa...d.php?t=129463
im not quite sure how the front bags can ever be taller than the spindles i have in there. Upper/lower A Arms are usually "parallel" right? and the spindle joins them on one side.
So if the spindle is fixed length, how could airbags raise or lower the truck?
what am i missing??
thanks
Old 12-19-2012, 10:59 PM   #8
stevencvn72
Kill Bill...et
The bottom of the bag sits in the lower A arm, the top sits in a pocket in the crossmember. The spindle connects to the upper and lower A arms. So essentially, when you inflate the bag, it moves the lower A arm away from your crossmember...not the upper A arm. I may have confused myself here a bit so let me know if I can explain more or if I'm just frustrating you.
-Steve
I Grease
'67 Chev stepper
Old 12-20-2012, 05:35 AM   #9
jks67ss396
that helps thanks!
Old 12-20-2012, 06:25 AM   #10
bk2life
put the taller cup on the top. this way the bag can still "move" and articulate with the lower arm.
its really a pretty easy thing to do, 6'inch pipe cut it to the length you need. add or take away as you figure out how long you need.
bk2life is offline   Reply With Quote
Old 12-20-2012, 06:41 AM   #11
One ton coils will raise a C/10 1"-2". I believe you can buy Air Lift bags for those. They sell bags to go inside rear coils,I know that. On a '70 C/10 I installed new C/20 coils and Air Lifts. I could jack that thing way up at max air or run the minimum and it sat about stock with a steel work top,tools,and ladders. I'd air them up just a bit to accommodate the load.
www.airliftcompany.com
Also,www.awdirect.com sells auxiliary air springs,not air bags. Those will stiffen it up with no adjustability.
Old 12-20-2012, 11:01 AM   #12
jks67ss396
Hey Tim
How was the ride with the C20 coils and air bags maxed out? How many inches did you gain running like that?
