Old 12-18-2012, 02:04 PM   #1
Rusty Wrenches
Rusty Wrenches's Avatar
interchanging control arms
Quick question. I searched a while and am coming up with nothing. I would like to put 73-87 lower control arms on My 66, I know you can swap the whole crossmember but I was wondering if you could just do the lower arms? It looks like they bolt on the same way, any help would be appreciated!
Rusty Wrenches is offline   Reply With Quote
Old 12-18-2012, 04:01 PM   #2
ERASER5
ERASER5's Avatar
Re: interchanging control arms
I hung 73-87 arms on my '70, I believe a '66 would be the same.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-18-2012, 04:15 PM   #3
SCOTI
SCOTI's Avatar
Yes the arms can be swapped. The steering stops are different because the later arms use diff spindles but it's not anything that prohibits swapping.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2012, 04:32 PM   #4
Rusty Wrenches
Great- So heres what I plan to run. My 66 uppers with original ball joints, 73-87 lower arms with 73-87 ball joints and 73-87 drop spindles. Should have no issues with this combination correrct?
Old 12-18-2012, 05:37 PM   #5
SCOTI
SCOTI's Avatar
You can run the 73-87 ball joints and 73-87 drop spindles on your current arms too... no need to replace unless the current ones are damaged.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2012, 07:26 PM   #6
Rusty Wrenches
the plan is to upgrade to a dropmember someday which would require the 73-87 arms, So i just want to be able to swap everything over. Sounds like I have a good plan put together, thanks for the help.
Old 12-18-2012, 09:19 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
66 uppers with 73-87 ball joints.....
Both upper and lower ball joints must be the newer style. You cannot use 66 ball joints either upper or lower with the later spindles.
Tx Firefighter is offline   Reply With Quote
Old 12-18-2012, 11:06 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
And you also have to use a 73-87 outer tie rod end,... which opens up another can of worms.
Keith
Convert to disc brakes.
Old 12-18-2012, 11:09 PM   #9
lolife99
lolife99's Avatar
From this thread:http://67-72chevytrucks.com/vboard/s...57&postcount=3
63-66 truck with:
73-87 Crossmember Not Yet Installed:
1) This swap is almost a direct bolt in, with just a few holes to drill/elongate.
2) The preferred method is to use all of the 73-87 steering linkage:
* This includes the centerlink, inner and outer tie rods, idler arm and steering box. (A great way to gain P/S)
3) If you must use the 63-66 steering components, you will need to change the tie rods:
* The 63-66 inner and outer tie rods are a smaller diameter (5/8") vs. the 73-87 tie rods larger diameter (11/16").
* The 63-66 tie rods are also the opposite thread direction of the 73-87 tie rods.
* 63-66 inner is RH thread vs. 73-87 inner which is LH thread.
* 63-66 outer is LH thread vs. 73-87 outer which is RH thread.
3.1) So to connect the 73-87 spindle to the 63-66 steering centerlink you must use a:
* 63-66 outer tie rod (LH thread) in the inner location.
* connect that to a tie rod "conversion sleeve". (these are sold by many aftermarket suspension companies).
* use a 73-87 outer (RH thread) to connect to your 73-87 spindle.
* Again,... it's much simpler to use all of the 73-87 steering components.
4) Connecting the 73-87 rubber brake lines to the 63-66 steel lines, may require steel line fabrication, or brass "inverted flare" adapters.
5) You can also just swap all the components, from the a-arms out,... and leave your original 63-66 crossmember in place.
* This will require you to completly disassemble both the original 63-66 suspension and the 73-87 donor suspension.
* This is also a good time to clean, inspect, replace or rebuild any needed components.
Keith
Old 12-19-2012, 01:10 AM   #10
Rusty Wrenches
Man it looks like I should just find a 73-87 crossmember to stick under my truck seeing how I need all new linkage already, hopefully I cab find one with everything. Any porterbuilt guys chiming in here? I need some of your junk! lol
