Old 12-18-2012, 11:31 PM   #1
hyche81
hyche81's Avatar
Front end weight
Any suggestions on front springs I need? Mustang II front end. Overall weight should be in the 3500 lb area with a aluminum headed bbc.
hyche81 is offline   Reply With Quote
Old 12-18-2012, 11:44 PM   #2
SS Tim
SS Tim's Avatar
Re: Front end weight
A lot more info would help. But unless you have done a lot to lighten the truck 3800-3900 sounds more likely. If you are not running A/C your front weight is probably going to be about the same as a A/C small block truck. Match up to the stock small block A/C springs capacity and rate and you should be in the ball park.
SS Tim is offline   Reply With Quote
