Old 12-19-2012, 07:01 AM   #1
blazercrazy70
blazercrazy70's Avatar
Need help on wheel backspace
I am looking at some 18x8 with a 4.75 backspace up front and 18x9 5.25 bs in back. Wondering what anybody thinks on tire sizes. Just looking for some suggestions.
blazercrazy70 is offline   Reply With Quote
Old 12-19-2012, 08:12 AM   #2
CC69Rat
CC69Rat's Avatar
Re: Need help on wheel backspace
Tell us more about your truck. Is it dropped? If so, how much? Will it have more of a sporty feel or stock? Do you like a taller sidewall, or minimal sidewall?
What year is the truck? Leaf springs or Coils? ..
Tire size calculation:
Example - 255/50/18
255/25.4 - This gives you the width of the tire in inches. - 10.04"
255/25.4*.50 (aspect ratio) - 5.01" sidewall (from the ground to the bottom edge of the wheel)
So, 255/25.4*.50*2+rim size. 5.01*2 = 10.02"+18 This tire would be 28.02" tall overall.
Not assuming you dont know .. just trying to help. this way you can nail it the first time. That's why I was curious how far it was dropped (if any) and how you planned to drive it (sidewall flex)
Also, do you know which rear end housing you have in your truck? It can change your backspacing around a little .. you want to make sure if you have gotten these backspacing numbers from somewhere else (?) that the two trucks have the same rear axle housing. On the numbers you posted up, I am assuming you have the late rear end. Late 70-72.
I can elaborate if you need the info.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-20-2012, 02:43 AM   #3
blazercrazy70
Truck is a 72 coil spring rear looking at the 4/6 drop from ECE. I want the fender wells filled. I believe the 255/50 were the size I was looking at. I want the sporty look. I may have to go to the 20's to get the look I want. They are 20x8.5 with 5.25 bs.
Old 12-20-2012, 02:54 AM   #4
carcollector6970
Thumbs up Re: Need help on wheel backspace
I just finished my 72 c10 and used 18x8.5 up front with a 245/50 with 4.5bs and a 18x9.5 with a 285/40 with 4.75 bs in the rear with a 5/6 drop kit. great clearance lock to lock in front and rear. i could send you more pics if you cant tell from my profile pic. thanks todd
carcollector6970 is offline   Reply With Quote
Old 12-20-2012, 04:45 AM   #5
blazercrazy70
Send me some pics it looks awesome in your profile pic. What wheels did you put on it. And did you use ECE for your drop
Old 12-21-2012, 12:30 AM   #6
carcollector6970
I used Belltech 3in drop spindles and 2in springs and 6in rear c-notch and deluxe trac-bar kit from cpp the wheels are ridler 695 wheels
