12-22-2012, 11:48 AM | #1 |
Sag question
My truck has leaf springs and when I haul a yard of gravel, it has too much sag. Would it be stupid to place wooden blocks between the axle and frame before loading the truck bed with gravel, etc., to limit the sag? I'm just looking for a cheap solution when I occasionally have to haul a heavy load. Thanks for any help.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter |
12-22-2012, 12:03 PM | #2 |
Re: Sag question
Thats sounds like a not so good idea... and define cheap... whats your budget?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
12-22-2012, 12:09 PM | #3 |
Cluster King
Re: Sag question
Cheapest solution that would be safe that I can think of would be air shocks.
12-22-2012, 12:27 PM | #4 |
20' Daredevil (Ret)
Re: Sag question
I would not use wood blocks. Air shocks will help, or air bags. I prefer overload leaf springs like these Hellwigs, about $100:
A cheaper alternative (about $30) is coil overloads that attach to the axle housing and contact the bottom of the frame under load. I have used these but now have the Hellwigs pictured above.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-22-2012, 01:52 PM | #5 | |
Re: Sag question
12-23-2012, 02:15 PM | #6 | |
Re: Sag question
12-23-2012, 05:22 PM | #7 | |
20' Daredevil (Ret)
Re: Sag question
As others have said, none of these will increase your safe payload beyond the GVWR of your truck. What they will do is keep your truck more level when loaded.
12-22-2012, 12:22 PM | #8 |
Re: Sag question
Cheap for me would be making my own stuff or using parts from the wrecking yard. But if none of that would work, I could spend up to $200.
12-22-2012, 12:58 PM | #9 |
the boat guy
Re: Sag question
Wood blocks would just make you bottom out the suspension at a higher ride Height. The only advantage would be the front end caster would be closer to what it is with no load.
Overload springs or air shocks get my vote. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-22-2012, 02:48 PM | #10 |
I am a Referee of life.
Re: Sag question
Look in the classifieds for a set of factory helper overloads.Once installed,they're out of the way and only work when the truck is loaded.Best of both worlds,yu get the benefits when you need,but don't have to remember to use them and they sholdn't affect the ride when not loaded.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-22-2012, 03:46 PM | #11 | |
Re: Sag question
Have you reviewed the owners handbook load charts? It has a GVW of 5000-lb and base V-8 curb weight is about 3750-lb. With a yard of gravel weighing about 2800-lb (105-lb/sq ft) you are somewhere above 1500-lb overloaded before you even get in the truck. If you have A/C and a step bumper you loose about another 200-lbs of capacity.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-22-2012, 05:42 PM | #12 | |
Re: Sag question
12-22-2012, 06:34 PM | #13 |
20' Daredevil (Ret)
Re: Sag question
Guess I'd better not admit to how much weight I have asked my truck to carry, nor to how many times...
Not that I would advise others to do so, but the truck hasn't complained yet. Well, it may have grumbled a bit, but it handled all I could throw at it (or in it) and lived to do it again. Under that sexy sheetmetal, she's a purty tough old workhorse.
12-22-2012, 06:58 PM | #14 |
Cluster King
Re: Sag question
You are not alone Stocker.
I have overloaded a few of my old Chevy's too. Why make two trips. I have had the rear bumper dragging pavement a few times and the old Chevy just did its job like a good Chevy should, not complaints. Sexy and tough in one package, you don't see that anymore. |
12-23-2012, 01:01 AM | #15 |
Re: Sag question
Little more money than you were wanting to spend. But I put air lift kit on mine. Keep about 9-10lbs in them when not loaded. Get's rid of the saggy look. When I tow or haul I add just enough to level it out. The added benefit that I really like.....it don't have near the body roll I used to so get a much better ride even when not loaded.
12-23-2012, 12:28 PM | #16 |
Re: Sag question
I had a bedload of wet dirt piled as high as the cab in the Longhorn. I had air shocks pumped to the max and have aux leaf springs. The tires hated it had to air the tires to almost 50psi to keep them up. If I was going more than a mile or 2 I'd have been in trouble. every bump made the front of the truck want to switch lanes. Lesson learned. The plywood sides came down for the next 2 loads.
It's not only because loads are heavy the rating is there. Handling and safety come into play.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
12-23-2012, 03:51 PM | #17 |
Re: Sag question
It appears you are on the right track, but just wanted to remind you that when you modify a vehicle, keep in mind that it isn't only about your safety, it is about the safety of the others on the road. The suspension is designed to keep your tires on the road for maximum traction. When you make changes, make sure you are not hindering that process.
Also, a heavier load means longer stopping distances. Make sure your suspension AND brakes are up to the challenge. It may not be your life that depends on it; it may be the car in front of you, beside you, or even the guy walking across the street not paying attention.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
