12-23-2012, 03:39 PM | #1 |
do tubular a-arms really warrant the cost?
i want to put tubular a -ams on my truck (1972 c-10 short box) but can't find alot of info on what you gain (performance wise) buy putting them on? and thoughts would be helpful.
olyhotrodz |
12-23-2012, 03:47 PM | #2 |
Re: do tubular a-arms really warrant the cost?
i'm thinking about that now too, besides getting the geometery better on the front end, which allows better front end alignment, i don't know if it's worth the cost.
interested to see everybodys input |
12-23-2012, 03:52 PM | #3 |
67-72 parts collector,…
Talk to Nate Porter at Porterbuilt.
He has several versions of his control arms. Definitely a great product! http://www.porterbuiltfabrication.co...arting-at-1049 http://67-72chevytrucks.com/vboard/s...d.php?t=537266 (plus,... have you priced all the parts to rebuild your stock a-arms?)
12-23-2012, 04:11 PM | #4 |
If your staying stock or as a stand alone product or miss matched with other things then no, it's not worth the cost. If lowering and as a complete system of matched components then yes, well worth the cost. Much improved steering, suspension, and tires last a lot longer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-23-2012, 04:23 PM | #5 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-23-2012, 04:36 PM | #6 |
Cluster King
If you just want the truck 2-3 inches lower in the front then I would use drop spindles and leave the rest alone. Drop spindles are designed to lower the truck and keep the front suspension geometry stock. When you use stock components, there is a limit to how far the caster, camber and toe can be adjusted and stay with in specs. No matter what, it is about tire wear and the tires ability to make the best contact patch on the road as possible.
12-23-2012, 05:46 PM | #7 |
When I bagged my truck I switched to tubular control arms upper and lowers....
I felt that they were worth for me to spend the $$$ to compliment the rest of the suspension on my truck.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-23-2012, 11:12 PM | #8 |
I just installed them on my 68. The reasons I did it, better geometry, less weight and they look way cooler!!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-23-2012, 11:36 PM | #9 |
12-23-2012, 11:48 PM | #10 |
I went with CPP because I still have coil springs in the front.
R/
12-24-2012, 12:16 AM | #11 |
You definately don't "need" them but they are cool. If I didn't have control arms and needed to buy some then sure, why not. As for advantages over stock, who knows. I've never had a problem aligning my trucks at any height. Longer camber bolts and shims and pie cutting ball joints. It's all easy to do. Tubular arms sure do look cooler though!
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
12-24-2012, 12:23 AM | #12 |
my christmas gift.....
some info....http://www.ridetech.com/store/1963-1...ont-lower.html
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
