Old 12-26-2012, 07:04 PM   #1
hilljob26
hilljob26's Avatar
where to hook to pull the engine
where are you guys hooking to to pull the ls engines from there original truck. i have a 01 yukon that i am getting ready to pull the motor, but i dont really see anywhere feasable to do it, are you guys removing the intakes,,im sure i will figure something out, just thought maybe somebody already had this delima and could point me one way or another
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 12-26-2012, 07:23 PM   #2
cableguy0
Re: where to hook to pull the engine
Use the bolt holes in the front and rear of the heads. Use opposite corners. Its better with the intake removed so you dont have to worry about the chain cracking it.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-26-2012, 08:53 PM   #3
mooseknuckles
mooseknuckles's Avatar
x2....tho I've seen a cool lifter valley cover lift plate, that might be worth buying/making....
mooseknuckles is offline   Reply With Quote
Old 12-26-2012, 10:05 PM   #4
Jdubs71
Jdubs71's Avatar
Mike,
My motor was already pulled so this may not help, but I moved loaded and unloaded it a couple times with the intake still on. I used a chain with a piece of pipe centered over the motor held taught with two bolts to keep the chain from breaking the intake. Finding the position to lift from was a little tricky, but you'll figure it out. I think I used a bolt on the rear where the bell housing bolts up and on the opposite side in the front, I believe it was a bolt threaded into the head because if I remember right I was afraid to lift from the aluminum head, but did it anyway. Here are a couple pics, hope it works for you.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 12-26-2012, 10:08 PM   #5
cableguy0
I havent seem that plate myself but that would be the best bet. Multiple bolt down points and a centered lift point.
Old 12-26-2012, 10:18 PM   #6
mooseknuckles
wouldn't be too hard to make either.....
Old 12-27-2012, 12:41 AM   #7
hilljob26
hilljob26's Avatar
ok, i was kinda thinkin the same thing,the last thing i want to do is break the intake,,thanks guys
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 12-27-2012, 02:24 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you don't have one, get a load leveler. Makes life a ton easier when you are pulling or dropping in an engine. I pulled my intake and then hooked my chains to 2 bolts installed into the bosses on the front of the heads, and then the rear 2 onto 2 of the bellhousing bolts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2012, 10:35 AM   #9
hilljob26
hilljob26's Avatar
i have one,,i was just trying to get a rough idea what these others did,,im so used to the old sbc that i usually pull the dizzy and force the engine out,,but with all the plastic,, i was tryin to be more careful
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 09-01-2014, 08:55 PM   #10
feller
feller's Avatar
i have googled this question and came up with all kinds of results, thanks this was a huge help.
feller is offline   Reply With Quote
Old 09-02-2014, 09:09 AM   #11
Roz
I just pulled mine from the donor truck last weekend. I removed the core-support, radiator, condensor etc. On the engine, I removed the coils as an entire unit(s) and removed the intake and alternator as well. I used and open bolt hole the passenger side cylinder head and the alternator bracket to remove the engine/trans as a complete unit.
Roz is offline   Reply With Quote
