Old 12-26-2012, 08:03 PM   #1
CC69Rat
CC69Rat's Avatar
McGaughys 4 wheel disc question
Some of the guys running the McGaughys 4 wheel disc kit .. Are your wheel studs a little short? Have you replaced them and if so, which part number did you use? I'd say I need about another 3/8".. (6 more threads or so ? )
The ones I have give me maybe 5-6 threads I'd just like to get a little more .. Is there a car out there running 1/2 20 like this we could cross reference?
thanks.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-26-2012, 08:36 PM   #2
70cst
70cst's Avatar
Re: McGaughys 4 wheel disc question
I don't know if you will find the answers in these threads but I thought I would post this for you.
McGaughys 13" Front Brake Kit Interchange Parts
http://67-72chevytrucks.com/vboard/s...d.php?t=462680
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-26-2012, 10:38 PM   #3
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Hey Chad, gringoloco's build thread covers this I'm pretty sure. -Buck
http://67-72chevytrucks.com/vboard/s...d.php?t=444746 post #980
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-27-2012, 05:28 AM   #4
skorpioskorpio
70cst can you edit your post to correct the link for the rear brake thread? You double dipped on the http// so it redirects as an invalid URL.
For some reason I can't LINK these up
skorpioskorpio is offline   Reply With Quote
Old 12-27-2012, 08:54 AM   #5
CC69Rat
CC69Rat's Avatar
Thanks Buck .. found it
http://67-72chevytrucks.com/vboard/s....php?p=5685458
Post #988 (ish)
Chad
Old 12-27-2012, 07:19 PM   #6
skorpioskorpio
OK, so I get this right the McGaughys 13" fronts are '96 C4 Corvette Gran Sport rotors with 2000 Silverado Single piston sliding calipers? ...and the 13" rears are also off the shelf GM rotors and calipers of some sort? ...and have integrated parking brake? I know when I called CPP they claim that you have to get the rotors from them, special some how, I'd really like to get brakes where I have more rotor choices and not be at the mercy of having to get replacement parts for some specific kit. If that means converting to 5 on 4 3/4 on all 4 corners, I'm OK with that. I'd rather spend a couple hundred on a pair of axles then be stuck without a rotor supplier 5 to 10 years out.
Old 12-27-2012, 07:44 PM   #7
CC69Rat
CC69Rat's Avatar
You're really really close ..
Front calipers are 2000 Silverado dual piston. I saw a Trailblazer (not an SS) this morning and the calipers looked a lot like the ones I have in my kit. I took them apart to paint them., they looked really familiar.
The rotors are 96 Grand Sport. McGaughys offers a drilled upgrade, I'm not sure about them but so far so good .. (mine are drilled) I haven't run them yet.
I'm not sure what the rear calipers are from, but they are single piston. Integrated parking brake that likes to pinch fingers. A good friend of mine had the same issue with the intermediate parking brake cable being a little short .. so don't be suprised if you have to re-work your parking brake tension / cable a little bit. Not a huge deal, but the cables in the kit are a bit short. (3" or so per side)
My only complaint with the kit the instruction are not really clear on how to mount the rear caliper brackets. It took me a couple times to get it right. Also they will take some minor shimming to get them perfect. Add a washer between the bracket here and there to shim it perfectly. (most kits will be no different)
The wheel studs in this kit could be a touch longer.. not a complaint .. If I had different wheels, it might be fine.
Other than that, man .. get it. It's the best kit for the money IMO. Summit carries their parts too. Just take the McGaughy's part number and plug it into the Summit 'search' box and it will come right up. If I had it to do over, I'd get the same kit. I have their drop spindles too on both my trucks. .. I really like their stuff. But really, check with Travis or someone here on the site if you have cash they might be able to save you some money.
I am going with a Wilwood MC, 1 1/8 bore and an adjustable Wilwood proportioning valve.
Chad
