Old 12-27-2012, 07:57 PM   #1
swells6367
swells6367's Avatar
1984 crate motor
I found out today I have a gm good wrench crate motor 84-85 I was changing the pan gasket and I have the oil pan that the dipstick can be on either side. mine is on the drivers side, my question is I am leaking oil from the place where the dipstick would be on the passenger side. what kinda of fitting is in the hole and how would I fix this problem.
Scott wells
1973 k10 81 7.2l power-train
swells6367 is offline   Reply With Quote
Old 12-27-2012, 08:38 PM   #2
Ziegelsteinfaust
Re: 1984 crate motor
I believe it is just a plug with a bit of RTV around it.
Take a flat blade, and drive it into the offending plug. Twist, and pry out. Clean up with brake clean. Apply a generous amount of RTV, and pop in the new plug.
I think a 9mm shell casing can be used if you have one of those around.
Ziegelsteinfaust is offline   Reply With Quote
Old 12-27-2012, 09:29 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The engines originally came with a steel slug that you drove into the unused hole. Kind of like a short dowel pin.
Tx Firefighter is offline   Reply With Quote
Old 12-28-2012, 10:29 AM   #4
MDc10
MDc10's Avatar
I had the same problem, I bought a crate and they give you 2 size plugs. The only problem is one plug is way to small the other plug seems a little big, I fabricated some to put there but I still have the plugs. Is the plug suppost to be so tight you have to beat it in with a hammer? If it gets plugged there's no way it will ever come out.
MDc10 is offline   Reply With Quote
Old 12-28-2012, 10:55 AM   #5
Tx Firefighter
Yes, you have to hammer the plug in place. It's not going to come out unless you take the oil pan off and come in from below with a hammer and punch to knock it back out.
Old 12-28-2012, 11:26 AM   #6
MDc10
MDc10's Avatar
Thanks for the info
