Help, I want my motor to look like this.
I want my motor to look like this. What kind of paint should I use? Is it exterior car paint with gloss on it? Will that withstand the heat of the block?
Re: Help, I want my motor to look like this.
Seymour enamel engine paint code EN-48 for chevy orange.
Rockin' a '66 and loving every minute of it ![]() |
Krylon ceramic high heat engine spray paint
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
This was done using the Ceramic from Duplicolor. Sorry its the wrong brand, guys! That is actually a correct 1959 Ford engine color.
OK I can redeem myself- here's my '69 big block using Duplicolor Ceramic in CHEVY orange. LOL
I was wrong, mine was duplicolor ceramic not krylon...... I know my pics dont show how shiny it is ( camera phone and poor lighting ) but it is actually very bright and shiny..... I love the ceramic paints
I even baked the paint on in an oven on all my small parts, made it even better
Yes, the duplicolor ceramic is the best I've seen so far. You can get it in pretty much every parts store. The cap is labeled "Chevy Orange". There are other colors that look similar on the cap, but they don't come out the right color.
no job in a spray can will get you that nice clean glassy gloss, I had the guy who helped me build my 327 use what he uses to paint his engines it comes in small cans or gallon size, I'll get back to you tomorrow about what exactly he uses he mixes it to the right viscosity, actually comes out VERY consistent, the valve covers were painted at a separate time from the engine as well.. and yes he uses a paint gun.
Who Me?
Now I want to go and paint my engine.. Those above look great!!! Way to inspire the rest of us
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Exactly! Makes me want to do the same thing! What process have some of you used in the past? Remove everything you can, degrease, clean, dry, then paint?
Just put a bunch of shinny stuff on it and you will hardly even notice the paint on the motor... Just my opinion
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
![]() Join Date: Jun 2011
i want my engine to look like this.
anybody have the or any paint code for 1965 283 V8 grey ![]()
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
I took a factory color valve color in and they mixed me a can, I don't know if the code is on it but I will look. I had 2 grey valve covers and both were original and they were different shades of grey so like the green, there are variations.
#15 |
Done with Duplicolor Chevy Orange from a spray can.
#16 |
I have painted many engines with straight automotive paint, either single stage or base/clear with zero problems. The trick is to make sure everything is clean, and then clean it two or three more times, dont paint under a bolt head or a mating surface for the exhaust, water pump intake, fuel pump, etc. The hardened paint helps with clean up down the road as dirt and oil dont stick like it does to aerosol paints. hope this helps.
#17 |
Depending on what you are doing, but on solid colors you can usually get just as good of a paint job out of a rattle can as you can with a paint gun. It's not as easy, but it can be done.
We've all seen cars that people painted with rattle cans that look terrible, and I was convinced at one point that you could never do near as good of a job with a rattle can until someone showed me an entire car painted with a rattle can the right way. Anyone would have been hard pressed to tell the difference. |
#18 |
I have had great results using VHT engine paint and VHT engine clear. The clear makes all the difference.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
#19 |
Also Duplicolor Chevy Orange.
#20 |
It could be like this!!
#21 |
Not exactly what wanted but it's close enough considering my budget. Thanks Guys!!!
#22 | |
You need to replace that oil cap on the drivers side valve cover with a breather. Just the pcv won't stop the oil leaks. You need somewhere for air to get into your motor so the pcv can suck out the fumes. You need to replace that rubber fuel hose with a steel tubing line. Big fire waiting to happen. |
#23 |
C/10 junkie
I used Rustoleum engine enamel $6 a can
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#24 |
Shawn did you also paint the pulleys or were those already black? Ya did a great job!!
#25 | |
C/10 junkie
