12-29-2012, 09:55 AM | #1 |
What size tires?
Well it would appear the cold weather and dry rotted tires has taken its toll on my truck since I found a flat this morning when I went to the garage. I tried to refill it with air but it just leaks back out. Currently the truck has 31 x 10.50 x 15 on 15x8 rally wheels. My LONG term plans are to lower the truck mostly likely with a 4/6 static drop, but with a baby on the way I don't know how far into the future that will be.
My question is, what tire size would you recommend? In a perfect world I would like a tire size that will work with it at factory ride height now and later down the road with a drop. I can say that right now I am looking at tires in the 28-29" range, will that work with a 4/6? |
12-29-2012, 10:13 AM | #2 |
Re: What size tires?
i like 275-60-15 mine is lowered slightly
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-29-2012, 11:10 AM | #3 |
x2
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
12-29-2012, 12:59 PM | #4 |
What about a 235/75/15? Its a taller tire so I think it will look good at its current height or lowered, but I am not sure if it will fit with a 4" drop in the front.
12-29-2012, 04:35 PM | #5 |
heres mine. 4.5/6 drop with 235/75/15 tires. i plan on changing them in the spring time. need something with a street/sport thread.
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018 |
12-29-2012, 04:38 PM | #6 |
Do you still plan to run the same size just with a different tread design or are you going to change size as well?
12-29-2012, 04:43 PM | #7 |
i plan on going alittle smaller(70 series maybe 60`s if i go to a 275 width). not set in stone yet.
12-29-2012, 07:27 PM | #8 |
70+ ( Old Skool Club )
Hope this helps. 235/75R15's are 28.86 inches high and 9.25 inches wide. 255 tires are 10.03 inches wide and the 60 series are 27.02 inches high and the 70 series are 29.04 inches high and that is what is my stock height truck in the attached pic. Personally I think with the 4/6 drop you are contemplating a set of 255/60's would work for now and with the drop. The attached threrad is currently running on the message boards and should give you some ideas.
http://67-72chevytrucks.com/vboard/s...43#post5778543
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-30-2012, 04:04 PM | #9 | |
12-30-2012, 04:32 PM | #10 | |
12-30-2012, 04:45 PM | #11 |
Thats a pretty good point, the extra width does help in the looks area. I could do a staggered set with 235's up front and 255's in the rear. I did see some 255 in front and 275 in the rear, my only concern is when I start to lower it. If I stick with the rally wheels I plan to go to with a 7" wheel up front to provide more clearance.
12-30-2012, 12:11 AM | #12 |
4/6 255/60/15 on 8 inch wide
Posted via Mobile Device |
12-30-2012, 10:49 PM | #13 |
These are the size combos I have come up with:
28" tires: -235/70 all 4 -235/70 front, 275/60 rear 29" tires: -235/75 all 4 -235/75 front, 255/70 rear -255/70 all 4 I like the idea of skinnier tires up front so I know that it will work when it comes time to lower it. Anyone else like one of these combos better for a 4/6 drop? |
12-31-2012, 12:44 AM | #14 |
245x60x15 front 275x60x15 rear
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-31-2012, 06:29 PM | #15 |
01-01-2013, 06:11 PM | #16 |
I know every truck is different, but does anyone have an estimate on what the max tire height is on the front with a 4" drop?
